Author Topic: Gas Cap?  (Read 959 times)
July 29, 2010, 05:31:19 AM
Read 959 times
MarshMarlowe196
Gas Cap?
« on: July 29, 2010, 05:31:19 AM »
I thought this was a stupid question, but maybe not...
I lost the gas cap on my 19-6 recently.  I went to order another one, and there's several sizes to choose from.  Does anyone know what size/where to order the correct gas cap for a 73' 19-6?
Thanks  :salut:
Key West 1720 / Yam C90
Sold: 1973 Aquasport 19-6
September 09, 2010, 08:53:28 AM
MarshMarlowe196
Re: Gas Cap?
« Reply #1 on: September 09, 2010, 08:53:28 AM »
(bump)
SeaBob?  Anyone?
September 09, 2010, 10:01:35 AM
Robob
Re: Gas Cap?
« Reply #2 on: September 09, 2010, 10:01:35 AM »
I had a slightly different problem, the cap that was on my 1995 175 Osprey when I bought it was cross threaded. I went through 2 Perko replacement caps that didn't fit properly and finally ordered a locking cap complete with fill tube from Overtons.
Bob on Tampa Bay
September 09, 2010, 10:03:50 AM
Re: Gas Cap?
« Reply #3 on: September 09, 2010, 10:03:50 AM »
measure the threaded opening, go to West, look at a few, take back the one/s that don't fit, or replace the entire fill fitting with a new modern one?  I doubt there is a spec on that old of a boat?? Just what I would do...
September 09, 2010, 10:44:00 AM
Re: Gas Cap?
« Reply #4 on: September 09, 2010, 10:44:00 AM »
Sorry, Jessie, without looking at it...can you post a pic of just the fill?  That will get us started...
September 09, 2010, 11:55:48 AM
Re: Gas Cap?
« Reply #5 on: September 09, 2010, 11:55:48 AM »
I have heard that there isn't a standard thread size for filler caps.  So getting one to match can be difficult.  I think flounders suggestion is your only option.  Buy what you can and see if one fits...  if not replace the entire filler neck.  Good luck
September 10, 2010, 02:12:03 PM
MarshMarlowe196
Re: Gas Cap?
« Reply #6 on: September 10, 2010, 02:12:03 PM »
Thanks for the suggestions guys
I am currently between homes. My boat is being stored several miles away from me and going back to measure the opening then buying possible caps is a tad inconvenient, but if that's what needs to be done then it can be.  I'm worried about moisture getting in, though the boat is covered and I have the filler hose temporarily plugged with a plastic bag at the moment.
I recently replaced the filler hose, and let me tell you, due to the hole size in the gunwale for the filler hose (barely a bigger diameter than the hose itself) and the overhang of the gunwale around the area, you almost had to be double jointed to get a hose clamp around the hose after you install a new filler neck.  If you drop a tool or a hose clamp, which I've done, it has a new home in the boat.  I'd really like to avoid installing one again (I've done it twice now  :oops: ).
If it wouldn't be too much trouble, could someone with a convenient, same circa 19-6 measure the diameter and TPI (threads per inch) of their gas cap and let me know?  Thanks for the help everyone   :salut:
