Author Topic: HELP! - electric draw?  (Read 2139 times)
August 01, 2010, 08:04:14 PM
jdevoid
Re: HELP! - electric draw?
« Reply #15 on: August 01, 2010, 08:04:14 PM »
yes- I put meter on the batt terminals- while running same 12.6
August 01, 2010, 08:27:08 PM
bumpster
    • http://www.xtremeled.com
« Reply #16 on: August 01, 2010, 08:27:08 PM »
Engines will be the problem. I had a hot rod shop for many years but I know less than nothing about outboards and im not afraid to admit it. I am sure one of the Bobs or some one else almost as qualified will chime in shortly.
On a side note , just so everyone knows, all my electrical parts have been ordered so the rewire of the 200 Osprey is about to start. pics and thread to follow shortly
August 02, 2010, 09:16:42 AM
« Reply #17 on: August 02, 2010, 09:16:42 AM »
Quote from: "jdevoid"
BTW- this may be an important bit of info-  when I purchased the owner reveresed the batt cables and blew the 80amp engine fuse. It started right up after replacement but a good amount of smoke came out of the battery access panel,
 :shock:     :(    :scratch:
That could have fried a good bit of your charging system.  Blowing an 80 amp fuse has about the same effect electrically as a sledgehammer does mechanically.  Check the volts on the engine terminals with the engine running.  If you get 12.2 there, your charging system has gone bye-bye - you don't need to check wiring any further.  You did not say what year model the Yamaha is - if it is a fairly recent model it probably has an automotive-type alternator charging system, not a stator/rectifier setup.  If your motor has the alternator setup, you might just have cooked the voltage regulator, which is not too expensive to replace.
August 02, 2010, 06:04:50 PM
bumpster
« Reply #18 on: August 02, 2010, 06:04:50 PM »
Quote from: "GoneFission"
  Blowing an 80 amp fuse has about the same effect electrically as a sledgehammer does mechanically.  .
Thats the funniest sh1t I have heard in a long time.
August 13, 2010, 01:14:11 PM
jdevoid
« Reply #19 on: August 13, 2010, 01:14:11 PM »
blown rectifier/regulator  replaced and all is well  even the smoke has stopped!!!!!  LOL
August 13, 2010, 04:18:36 PM
« Reply #20 on: August 13, 2010, 04:18:36 PM »
Like Cap'n John said about the sledgehammer...it's not exactly a "precision adjustment tool"... :shock:
August 13, 2010, 08:23:21 PM
« Reply #21 on: August 13, 2010, 08:23:21 PM »
Glad to hear all is well!  Now let's go fishin'!
