hey thanks for the input so far. well im really looking for draft but if im only gonna give up an inch or so for speed thats not to bad of a sacrifice. i lightened up the boat significantly and wouldnt mind kepin it real shallow. how much would i be strugglin with the 115 if the boat is light. i mean i ripped out all the old wet foam in the stringers and under deck and all the plywood from the deck and im replacing all them 4lb stringers foam and glass and redoing the deck in foam instead of plywood. more opinions please... o ps. i have a 26 gallon fuel tank.
Quote from: "aquaterra"hey thanks for the input so far. well im really looking for draft but if im only gonna give up an inch or so for speed thats not to bad of a sacrifice. i lightened up the boat significantly and wouldnt mind kepin it real shallow. how much would i be strugglin with the 115 if the boat is light. i mean i ripped out all the old wet foam in the stringers and under deck and all the plywood from the deck and im replacing all them 4lb stringers foam and glass and redoing the deck in foam instead of plywood. more opinions please... o ps. i have a 26 gallon fuel tank.The differnece in wieght between a 150 v6 and a 115 v4 is about 60lbs maybe. thats the weight of a 9-10 yr old kid.
Quote from: "aquaterra"how much would i be strugglin with the 115 if the boat is light. Ha! Im currently running a 90hp Tohatsu on my 19-6 and a 45 gal tank. With full fuel and 4 adults I can run 32mph @ WOT, Add 2 kids and im still at the same speed. These boats have very little bow lift in the hole shot, they're practically on plane through the entire throttle range. With the 90hp I notice the waterline is just below the scuppers.I think a 115 or ideally a 130 Etec would be perfect for the 19-6.Heres and interesting read about HP from back in the day. http://www.classicaquasport.com/gallery ... 542/page/1
