Author Topic: Fuel filter change how often?  (Read 978 times)
July 24, 2010, 12:06:39 PM
Read 978 times
Robob
« on: July 24, 2010, 12:06:39 PM »
I have been changing my Sierra fuel filter (#18-7846) that is about the size of an oil filter every 6 months to get rid of any water due to ethanol in the gas even though I do not use the boat very much and keep the gas tank full.
I have been buying non-ethanol gas for a while and most of the ethanol should be very diluted by ths time.
I am thinking about an annual change instead. It isn't expensive, just less maintenance to do. Is this often enough?
Thanks,
Bob on Tampa Bay
July 24, 2010, 01:32:46 PM
Re: Fuel filter change how often?
« Reply #1 on: July 24, 2010, 01:32:46 PM »
I never changed a filter element more often than annually before ethanol and never had an issue.
This is with ethanol after 6 mo.
Looks like it must have gotten half full of water and sat for awhile.  Sometimes my old brain forgets about draining the bowl after a trip.
I just changed another filter this week and have been letting the gasoline dry out.  Maybe today I will cut it open and compare.
July 24, 2010, 02:23:09 PM
Robob
« Reply #2 on: July 24, 2010, 02:23:09 PM »
Ethanol is a politically driven cruel expensive con:-(
Bob on Tampa Bay
July 24, 2010, 03:09:56 PM
« Reply #3 on: July 24, 2010, 03:09:56 PM »
Total con and should be a crime.
Okay, here is the latest filter.  The only difference is that all of my gas for the last year goes through a Mr. Funnel which a friend turned me on to and I'm pretty sure I drained the Racor bowl after each trip.
http://www.mrfunnel.com/Mr._Funnel/Home.html
This time the only rust is on the top perforated plate.
As you can see, there were almost zero contaminates.  Inside the circles is a smudge of dirt right at the bottom of the pleat.  I'm almost positive that is the rust off of the top plate.  I attribute the lack of contaminates to the Mr. Funnel.
I dumped the gas from the filter and the water separator bowl into a coffee filter.  I'm pretty sure the brown is super fine rust from the filter top plate.  Another damn sliver of red plastic which I assume got into my tank from a new gas can before I bought the Mr. Funnel.
July 25, 2010, 09:44:10 AM
Robob
« Reply #4 on: July 25, 2010, 09:44:10 AM »
Thanks for the tip. It's cheap insurance.
I just ordered one.
Bob on Tampa Bay
July 26, 2010, 11:41:22 AM
« Reply #5 on: July 26, 2010, 11:41:22 AM »
Did you guys get the largest Mr. Funnel?
July 26, 2010, 12:56:00 PM
« Reply #6 on: July 26, 2010, 12:56:00 PM »
I would go large if filling from a gas pump.
Normally I fill my skiff from 5 gal. cans because I seldom ever need 10 gal. at one time.  Plus my skiff takes gas so slow that even at the pump I have to fill very slowly to prevent overflow.
July 26, 2010, 03:12:05 PM
Robob
« Reply #7 on: July 26, 2010, 03:12:05 PM »
I ordered the FC3. I fill up at my dock from 5 gallon cans so it should be fast enough.
July 29, 2010, 01:23:53 PM
MTBfish
« Reply #8 on: July 29, 2010, 01:23:53 PM »
Newbee question here...   Where is this filter located?  And would you know if a 02 215 Explorer has one?
Thansk, marc
