Author Topic: Toggle Switches for 1995 Aquasport Explorer  (Read 1742 times)
July 21, 2010, 06:42:40 PM
Read 1742 times
kb2ski
« on: July 21, 2010, 06:42:40 PM »
I am up to my eyeballs in ordering parts and planning to run wires and I was wondering if anyone can help me cross reference some factory switches in the guage console on this boat.  Fortunately, I found  20A ETA 1658 push buttom circuit breakers.  I need 11 of those.  I am looking to cross reference the correct toggle switches but nothing comes up under Carling patent pending 12Volt Mexico 9223. There is not any other distinguishing marks on them.  I would like to make sure I buy the correct switches to replace all of them on the dashboard.
Does anyone have a great one stop shop to buy wire, 10 flip toggles, 1 on-off-on toggle. I would also need to boots to cover them.  it looks like they are illuminated red but I may not opt for this depending on the cost.  Please post a response back.  Thanks.
July 21, 2010, 07:06:45 PM
bumpster
    • http://www.xtremeled.com
Re: Toggle Switches for 1995 Aquasport Explorer
« Reply #1 on: July 21, 2010, 07:06:45 PM »
genuinedealz.com
One stop shop for a rewire. How do I know this you might ask. I am rewiring a 94 200 osprey and doing alot of electrical upgrades
Dont go cheap on your boats electrical. If you cant afford to do it right You will never be able to afford to do it over! Stay away from butt connectors. My boat is being redone because after 16 years pumps broke and fixtures just got old. when the boat was only a year or two old the original wiring started to give me issues. ripped apart the dash bought new switches and soldered and shrink tubed everything. If I wasnt doing all the lighting and pump upgrades and adding fixtures I could leave my wiring from 14 yrs ago alone.
July 21, 2010, 07:50:48 PM
« Reply #2 on: July 21, 2010, 07:50:48 PM »
Bum,
Ya did good.  Any of the toggles will work.  Here's what genuinedealz has, which are near identical to what is on your switch panel...http://shop.genuinedealz.com/Marine%20Electrical%20Supply/Toggle%20Switches/
July 21, 2010, 07:54:52 PM
« Reply #3 on: July 21, 2010, 07:54:52 PM »
Start here.
http://www.marineengine.com/parts/sierr ... /index.htm
Scroll down to toggle switches and nav through to you see the ones you need. Those are plastic and some are lit. They are a direct fit. I'm not sure how the 95s were set up. In the 91, the handle is lit white/clear in the off position, red in the engaged mode.
I replaced all mine in my 91WAC. You will also find the rubber boots for these toggles. Boots will be gray not black but look fine. They also carry the fuse holders but you say you have those already.
July 21, 2010, 08:18:14 PM
« Reply #4 on: July 21, 2010, 08:18:14 PM »
Good job guys - that's what this forum should be about - questions, answers, and good info.
 :salut:  :salut:  :salut:
July 23, 2010, 11:53:50 AM
cdoyal
« Reply #5 on: July 23, 2010, 11:53:50 AM »
I used these on my 245 Explorer re-wire project: http://www.cmsquick.com/prod_17act%20sym_text.jpg
1997 245 Explorer w/225 Johnson Ocean Runner
July 24, 2010, 11:55:10 AM
Robob
« Reply #6 on: July 24, 2010, 11:55:10 AM »
I bought some plastic switches from this company and have been very satisfied with them.
http://www.wiringproducts.com/contents/en-us/d267.html
Just another source.
July 27, 2010, 10:49:15 AM
kb2ski
« Reply #7 on: July 27, 2010, 10:49:15 AM »
Quote from: "GoneFission"
I really appreciate the support from all who responded.  This is a great site with boat enthusiasts.  I did order some items from guinuinedealz.  They are a good outfit.
