Author Topic: 69 flatback rebuild  (Read 18090 times)
August 19, 2011, 01:59:10 PM
Reply #75
Capt Matt
Re: 69 flatback rebuild
« Reply #75 on: August 19, 2011, 01:59:10 PM »
Just a few pictures of the slow progress before paint
Capt Matt
Gunnel panels all fitted
forward bulkhead panel  fitted
final fairing of my hatches and drain channels
Light tackle sportfishing
August 19, 2011, 06:06:31 PM
Reply #76
« Reply #76 on: August 19, 2011, 06:06:31 PM »
Looks good - those are some deep drain channels - are they going to drain somewhere?
August 20, 2011, 12:40:52 AM
Reply #77
« Reply #77 on: August 20, 2011, 12:40:52 AM »
There is light at the end of the tunnel. You are now at the finish stage. Look to the other great recent completions here for inspiration :thumright:
Like the short casting deck, with flush-deck storage behind.
Good work.
August 20, 2011, 11:22:35 AM
Reply #78
dirtwheelsfl
« Reply #78 on: August 20, 2011, 11:22:35 AM »
you just lay up some smooth panels to set in the gunnels?
August 20, 2011, 08:38:06 PM
Reply #79
Capt Matt
« Reply #79 on: August 20, 2011, 08:38:06 PM »
Thanks for the pep talk, I need it. Days of work without seeing anything, then in less than a hour she will be in primer.
I've been using cheap can's of spray on primer just to find the holes to fill, fare etc. Seems to help.
Drain channels drain right out of the boat, the front two are connected and will go out the starboard side by the original drain and the back two hatches will drain straight out the transom. Hoping for a very dry bilge.
Fiberglass 4X8 panels where made on a smooth surface with spray on pam then cut to fit the spaces between gussets then used thin cabasol to stick them. Looking for that smooth factory looking finish. I just could not seem to get it that flat by skimming and sanding. Seemed like a faster way to go too.
Capt Matt
August 20, 2011, 10:24:58 PM
Reply #80
« Reply #80 on: August 20, 2011, 10:24:58 PM »
Pep talks are great. Support is better 8)
Re the glass inserts. Great this topic has been brought up. We were struggling up here as to how to best finish the interior.
You're right. Spend an inordinate amount of time sanding, fairing, sanding, fairing....and then when you finally spray...well, guess it looks okay. Translation: nobody's happy...a weak point.
Your idea is exactly what we're going with. Thin glass panels to mimic the former "liner". If you could call it that. Basically was two thin glass panels from the casting deck aft. Not tied/adhered at all to the outer hull; floating from the floor to the gunnel screws. Just the way the builders did it then.
We figured the new panels would serve three purposes. First, a great looking finish, back to original appearance or better. Second, sound-deadening when running. Third, additional stiffening, especially given the non-factory adherence.
Good work.
August 26, 2011, 07:41:49 PM
Reply #81
Capt Matt
« Reply #81 on: August 26, 2011, 07:41:49 PM »
A few last pictures before final paint. Rain stopped us from spraying today. What do you think of my Pine Island paint both lol
Did get it sprayed in primer weds then the final sanding, spot putty, more sanding the last 2 days
With my extra time today I glassed pads of coosa in cabinet to hold water separator, hydro pump for power pole and porta lift.  Should be able to roll deck with Kiwi grip by Sunday. Any one have any tips on application of Kiwi grip, I have 2 gallons of grey but was hoping to have enough to paint inside console and cabinet.
Capt Matt
Masked out and ready to go
Mounts for cooler tie downs (105qt Yeti)
Gunnel panels faired in and glazing putty sanded
Deck hatches and cabinet ready for paint
August 26, 2011, 08:13:48 PM
Reply #82
« Reply #82 on: August 26, 2011, 08:13:48 PM »
lookin' good Matt  :thumright:
August 27, 2011, 02:16:53 PM
Reply #83
« Reply #83 on: August 27, 2011, 02:16:53 PM »
Gonna be a great boat!  This is the fun part...
August 29, 2011, 06:44:14 PM
Reply #84
Capt Matt
« Reply #84 on: August 29, 2011, 06:44:14 PM »
Paint is done, Kiwi gripped the deck/ top of cap and put the rub rail on yesturday. Today I started putting in rod holders, pop up cleats etc. The end is near now, should be dropping her off to be wired by the end of the week. Tower went in for powder coating this morning and I should have it back by Friday.
Anyone else think she looks like a FWC boat all grey like she is? just needs a black stripe and people will get out of the way.
Capt Matt
August 29, 2011, 06:52:49 PM
Reply #85
« Reply #85 on: August 29, 2011, 06:52:49 PM »
She does  :lol:
Looking good Matt.  Lots of holes there - what's going in the console?
August 29, 2011, 08:41:04 PM
Reply #86
« Reply #86 on: August 29, 2011, 08:41:04 PM »
Looks Great! :thumleft:
The FWC look will cetainly keep boats away. :thumright:
August 29, 2011, 10:22:33 PM
Reply #87
« Reply #87 on: August 29, 2011, 10:22:33 PM »
Man, I love that transom cap curve. I disagree with the FWC remark, that boat is way too sweet looking to be mistaken for a government ride!
Well...... maybe from a distance! :shock:
I wonder if there is some kind of a removable black stripe? You could really mess with people especially if you're in a tournament and come flying up on a spot somebody's already on. Hell, they'd all freak and haul butt outta there.  :lol:  :lol:  :lol:
If you had the stripe I wonder if you could get away with running the no wake zones like they do.
I guess it would work once , I don't know about the second time though!!  :roll:  :roll:
August 29, 2011, 10:36:35 PM
Reply #88
« Reply #88 on: August 29, 2011, 10:36:35 PM »
Quote from: "RickK"
She does  :lol:
Electronics and access hatch.  Looks awesome!  The ribs in the inwales...she's going to be stout.
Wished you'd have contacted me on the wiring/rigging... :D
August 29, 2011, 10:37:57 PM
Reply #89
« Reply #89 on: August 29, 2011, 10:37:57 PM »
Quote from: "slvrlng"
Lewis, ever hear of impersonating a LEO? :shock:  :shock:
