Engines & engine woes
Trim is stuck!!!!
Topic: Trim is stuck!!!! (Read 2208 times)
July 13, 2010, 10:37:36 PM
Read 2208 times
The Rodfather
Trim is stuck!!!!
July 13, 2010, 10:37:36 PM »
My trim is stuck. When i try to pick it up it always stops about quarter way up. "BOOM" It sounds like it slams into something but i see nothing in the way. i just got the boat (1986 aquasport osprey 200) and need to fix a few things on it. This is the next thing on my list. Its got a Mercury 150 Mariner slapped on it. if someone could help that would be great. Im also going to be asking for some help in other areas of my renovation. the boat has been sitting for about six years. by other areas, i mean . . . . soft spot on floor, leaning post(build or buy), console
remodel, live-well function, glass refinish / paint. thanks.
1986 Aqua Osprey 200 C.C.
2005 Honda 450R w/nitrous
2007 Suzuki LTR 450
July 13, 2010, 11:14:55 PM
Re: Trim is stuck!!!!
July 13, 2010, 11:14:55 PM »
welcome rf!some pics would help.your trim could be low on fluid
2003 Osprey 225
July 14, 2010, 05:30:38 AM
July 14, 2010, 05:30:38 AM »
Welcome aboard Rod :!: :!:
July 14, 2010, 06:56:28 PM
The Rodfather
July 14, 2010, 06:56:28 PM »
Hey thanks for replying. i will have some pics up soon. . . . about the low fluid level idea, wouldnt i need to have the pistons all the way extended to check/fill the fluid? that means i would need the trim to be up. wheres my shotgun
2007 Suzuki LTR 450
July 14, 2010, 07:39:52 PM
Mechanical Master
July 14, 2010, 07:39:52 PM »
Try loosening the manual release screw in the lower portion of the transom bracket(I think on the right hand side) and see if you can pull the engine up by hand. Usually about two turns out. How does the trim motor sound when it stops? Does it begin to bog down or free wheel and pick up speed. Do you have a single piston or 3 piston system? If you can raise the motor by hand with the manual release valve open then tilt it up all the way and engage the trailering support arm and check the fluid. Fill it if it is low with power steering fluid or ATF, close the valve and try trimming it up and down.
July 14, 2010, 08:51:49 PM
The Rodfather
July 14, 2010, 08:51:49 PM »
it has a three piston setup. well, i trimmed it up til it stopped, and it makes a slamming sound, and the motor begins to sound like its struggling to try and get up past that point. the motor sounds fine going up, and very much slower on the way down. while trimmed up to that annoying stopping point, i cracked the valve a couple turns, and the motor falls a tiny bit. so then i push it the rest of the way down...it is very hard to push, and no fluid comes out of the valve...even after the sixth or so try. should fluid be coming out? and when the valve is cracked, even while all the way down, i can not lift the motor at all manually. THANKS.
2007 Suzuki LTR 450
July 14, 2010, 09:31:36 PM
Mechanical Master
July 14, 2010, 09:31:36 PM »
Hey Rodfather,
No fluid should come out; it is only an internal bleed valve that bybasses a check valve. I`m beginning to think it may be your tilt bushings are frozen up from corrosion. try pumping some grease into the zirk fiiting in the middle of the tilt tube. That lubricates the tilt tube bushings. If it wont take grease you are going to have to heat up the tube near the bushings on each side and try to pump grease into it. Use a propane torch to do the heating. Sometimes, salt will get between the bracket casting and the bushing and squeeze the bushing tighter against the tilt tube and try to lock it up. Get the fuel line out of the way when you do this.
You should be able to move the engine up and down with the release screw open even if something is wrong with the tilt system unless it is full of water.
July 14, 2010, 09:52:17 PM
The Rodfather
July 14, 2010, 09:52:17 PM »
hey fitz, thanks for helping. i got a big project on my hands. im not too farmiliar with boat construction and overall function, but im excited to learn and the boat will be sweet when im done. i greased it yesterday, but im not too sure if it was taking though. should i change the zirk? shouldn't it splooge out the sides if it takes well? friday i will heat it up. ya i cant budge the motor up with my bare hands. no, im not being a wimp. :cyclops:
2007 Suzuki LTR 450
July 14, 2010, 10:30:14 PM
July 14, 2010, 10:30:14 PM »
I was already suspecting the tilt tubes/bushings. Now I'm convinced.
July 15, 2010, 09:07:38 AM
Mechanical Master
Reply #9 on:
July 15, 2010, 09:07:38 AM »
Good morning Rodfather,
I want to make sure we are heading down the right path here. When the "boom" occurs is it at the end of the trim ram limit? In other words, when the two smaller trim rams have fully extended is that where the boom occurs? Or is it in the middle of the trim or tilt range?
July 15, 2010, 02:59:38 PM
Reply #10 on:
July 15, 2010, 02:59:38 PM »
I'm wondering what Fitz asking about too. Does the problem start where the tilt cylinder is supposed to take over from the trim cylinders?
Oh and a stuck tilt/steering tube SUCKS. I had that happen to my Force. The grease hardened up like glue. I had to heat it with a propane torch to soften the old grease to free it up.
July 17, 2010, 05:32:25 PM
The Rodfather
Reply #11 on:
July 17, 2010, 05:32:25 PM »
i think the two trim pistons are maxed out when it stops tilting. so maybe the center big hydraulic is stuck.... should i try to heat that up? im going to unbolt the two little pistons to see if i can move it then.
2007 Suzuki LTR 450
July 17, 2010, 08:47:38 PM
Reply #12 on:
July 17, 2010, 08:47:38 PM »
If you heat the hydraulic cylinders you will ruin the seals.
July 17, 2010, 09:48:16 PM
Mechanical Master
Reply #13 on:
July 17, 2010, 09:48:16 PM »
NO HEAT! Make sure that there is nothing mechanical that is binding this up. Try having a second person run the trim up while you lift up on the gearcase. Back out that trim release screw and try again to raise the engine without running the trim system. It may take two people to lift the engine up. Get access to the fluid reservoir screw with the engine up on the trailer lock lever and check the fluid level and cleaniless.
July 18, 2010, 05:54:48 PM
The Rodfather
Reply #14 on:
July 18, 2010, 05:54:48 PM »
I got the trim up!!!! i guess i was being a wimp. we cracked the valve on the side and it took two of us to pick it up. so it is up. . . yay! i took off the cap and i see no oil, how high should i fill the resevoir?
2007 Suzuki LTR 450
Trim is stuck!!!!
