Replacing the deck and weight
Topic: Replacing the deck and weight (Read 934 times)
July 08, 2010, 05:18:06 PM
Read 934 times
saltfly
July 08, 2010, 05:18:06 PM »
Ok guys I'm replacing my deck. On my 222 ccp. Just getting to may soft spots. So here is my question. Is their a second layery of glass? You know, the top layer of glass, the wood, then a second layer of glass, between the deck wood and the stringers.
My other question is somthing I know some of you have already done. The coffin box in front of the console. I moved it one day to clean under it. Man is that thing heavy. Does anyone know its weight? I know some of you have taken it out and i'm thinking about removing it as well. Replacing it with a large ice chest, which has got to be alot lighter. Would save on gas.
Don't understand why the imge isn't showing up.
July 08, 2010, 05:31:33 PM
Re: Replacing the deck and weight
July 08, 2010, 05:31:33 PM »
I have no clue what the coffin weighs but that sucker is really heavy. I almost blew a gasket trying to get it out of my CCP by myself. I replaced mine with a 90 qt. Igloo with a cushion crossways right in front of the console and then mounted a 162 qt. Igloo longways like the coffin box. I used the 90 for
almost
dry storage and seating. I used the 162 for a fish box. I had room to walk all the way around the 162 and the people seated on the 90 could use it for a foot rest. I still had access to the front floor hatch as well. Both coolers weighed much less than the coffin.
July 08, 2010, 05:32:53 PM
Rigging Master
July 08, 2010, 05:32:53 PM »
This better?
July 08, 2010, 05:35:23 PM
Rigging Master
July 08, 2010, 05:35:23 PM »
BTW, love the hullsides, but she needs some graphics...
July 08, 2010, 05:37:24 PM
saltfly
July 08, 2010, 05:37:24 PM »
john you got that right. Man when I unbolted it and tried to get it out. I stopped and said no way. I think when I do remove it. I will take it to a friends house and use his over head hoist. All I have to do is drive under that.
Yea What did I do wrong and you did right?
July 08, 2010, 05:45:39 PM
saltfly
July 08, 2010, 05:45:39 PM »
seabob4 It had a name on it as well as Aquasport 222 ccp. I took it off. I saw a thread on here to make a new logo. I'm going to use that. It worked out well. I was going to ask what you guys do. When I found that thread. As for the name. I don't think I will do anything yet. I'm really not finished with th outside painting. Before I put the last two coats on. I want to do the deck. Don't want to mess up the hull finish when removing the deck.
July 08, 2010, 05:46:12 PM
Rigging Master
July 08, 2010, 05:46:12 PM »
Probably got a space in the code. If it's not "exactly", it won't come up...
I just copied your http address into my search bar, pasted it back into my reply, then made sure my BBCode was correct...
July 08, 2010, 05:48:41 PM
Rigging Master
July 08, 2010, 05:48:41 PM »
Salt,
We used to offer that same hull color on Tournament Master packages a while back, she would be awesome with the TM logos...
July 08, 2010, 06:02:07 PM
saltfly
July 08, 2010, 06:02:07 PM »
TM logos???? I'm a little slow.
July 08, 2010, 06:22:03 PM
Reply #9 on:
July 08, 2010, 06:22:03 PM »
"tournament master"
sticker on left :flower:
2003 Osprey 225
July 08, 2010, 06:34:00 PM
saltfly
Reply #10 on:
July 08, 2010, 06:34:00 PM »
Ok
gotcha Yea that wouldn't look bad.
sence I'm a flyfisherman (thats why the tee top is as little as I could find.) I was thinking of a fly line in mid cast with a deciever fly. I have a friend that is a master with a air brush.
July 08, 2010, 07:30:07 PM
saltfly
Reply #11 on:
July 08, 2010, 07:30:07 PM »
seabob4 thanks I reread your post. It finally hit me what you said. The bbc code. I went back and looked. mine was still checked.
