Author Topic: wiring harness headaches  (Read 1598 times)
June 21, 2010, 02:31:02 PM
Read 1598 times
« on: June 21, 2010, 02:31:02 PM »
anyone have a wiring diagram/color codes for 1996-current V-4 john'rude? 1996 112 SPL to be exact... seems theres a few wires that aint the same between 1990 and '96
June 21, 2010, 04:23:57 PM
Re: wiring harness headaches
« Reply #1 on: June 21, 2010, 04:23:57 PM »
Aswaff,
Go here...http://continuouswave.com/whaler/reference/wireColorCode.html
As much as I and Jim Hebert on CW don't get along sometimes, the guy does know his :*:... :shock:
June 21, 2010, 04:47:21 PM
« Reply #2 on: June 21, 2010, 04:47:21 PM »
thanks bob!  :cheers:
i still seem to have a few wires left over? everything is working though :scratch:
June 21, 2010, 05:36:19 PM
« Reply #3 on: June 21, 2010, 05:36:19 PM »
What are the colors of "what's left over"?
June 21, 2010, 05:46:16 PM
« Reply #4 on: June 21, 2010, 05:46:16 PM »
im assuming they are alarms,
tan/orange
tan/yellow
tan/black
June 21, 2010, 07:04:14 PM
« Reply #5 on: June 21, 2010, 07:04:14 PM »
Aswaff,
Here's a pic of an OMC alarm I have...
purple and a tan w/blue stripe...
I gotta guess those are alarm wires, like you said.  Do you have a "System Check" tach or gauge?
June 21, 2010, 07:23:53 PM
« Reply #6 on: June 21, 2010, 07:23:53 PM »
i pulled the gauge panel, all the tan and tan with stripe wires lead to the alarm, and disappear in that black vinyl tube. its a 3 wire alarm, black, purple, and tan...
no system check gauge? oh well... i got spark, it cranks trim works electric choke works, its all i need lol :bounce:
June 21, 2010, 07:38:06 PM
« Reply #7 on: June 21, 2010, 07:38:06 PM »
Aswaff,
You got it, bud! :cheers:  :cheers:
June 23, 2010, 12:53:36 AM
« Reply #8 on: June 23, 2010, 12:53:36 AM »
here is a link to another source for the color code:
http://www.maxrules.com/fixOMCCwiringcodes.html
July 06, 2010, 10:10:34 AM
« Reply #9 on: July 06, 2010, 10:10:34 AM »
so i finally have a day off where its not raining, fired the motor up, as i would suspect, the kill switch(key off) is not grounding out... here come the headaches :?
otherwise the motor runs great! :cheers:
July 06, 2010, 10:55:32 AM
« Reply #10 on: July 06, 2010, 10:55:32 AM »
So when you pull the lanyard, you're not getting continuity across the 2 terminals...
Hell, you oughta have a bunch of kill switches laying around the shop, easy R & R... :thumleft:
July 06, 2010, 04:00:25 PM
« Reply #11 on: July 06, 2010, 04:00:25 PM »
its the key/kill switch combo, when i turn the key off its not grounding the coils...
put the boat in the water, holy crap! it got up to 40 mph in a heartbeat! :shock: too choppy to go any faster than 35 without beating the boat to hell, only got it up to 40mph (less than 3/4 throttle).... pulled up to the dock at my work to top off the tank with some fresh gas, went to pull away, nothing, shift cable broke  :ncool:
July 06, 2010, 04:23:49 PM
« Reply #12 on: July 06, 2010, 04:23:49 PM »
You've got a break in the ground wire somewhere in that engine harness... :evil: Do a continuity check between the coil ground wire on the motor and the key switch.  Maybe it's just the key switch, which feeds the kill switch.
Sorry about the cable... :x
