Author Topic: Need part number and manual for 1994 Aquasport 250 Explorer  (Read 839 times)
June 20, 2010, 02:26:59 PM
Read 839 times
kb2ski
I recently purchased and 1994 Aquasport 250 Explorer with twin Evirude 200 OceanPro motors.  I don't the keys to the cuddy and I have a lot of work to do on the boat to get it ready for the water.  I am trying to find some good places to buy parts for it.  I would like to be able to buy some switches and laundry list of other items that will be needed to build this boat up again.  I have searched for a parts manual but have not found much of anything out there.  Can someone point me in the right direction to find part numbers for this model so I can cross reference what I need?  Thanks.
June 20, 2010, 02:51:33 PM
Re: Need part number and manual for 1994 Aquasport 250 Explorer
« Reply #1 on: June 20, 2010, 02:51:33 PM »
Quote from: "kb2ski"
That is going to be a VERY tall order!  The Aquasport line was discontinued in 2005, and most of the resources that Genmar had in relation to parts and otherwise were not bought up to the Four Winns plant in Cadillac, MI, when Wellcraft shut down Sarasota and moved there.  That was who was building your boat at that time (Genmar owned AS, WC, and a ton of other builders)...
However, you have come to the right place, as most of us can identify, with the help of your pics, the hardware used on your boat and where to get replacement parts.  BTW, where are you located.  And also, WELCOME ABOARD!!! :salut:   You have bought one of the best boats out there (don't let others tell you different) and you have joined the best owner's site on the net!
June 20, 2010, 04:20:16 PM
« Reply #2 on: June 20, 2010, 04:20:16 PM »
Welcome aboard KB  :!:  :!:
Here is a start for data: http://www.classicaquasport.com/gallery/showphoto.php/photo/2778/sort/1/cat/547/page/1
Your Explorer is a model built for only a few years and I think they only made 212 or something like that and then they went back to the usual Explorer model like I have.
What do the locks to the cabin look like?  Are the keys round?  Mine are and I also didn't get keys to mine, luckily it was unlocked - found them at ACE hardware - ended up being a freezer door lock.
As SeaBob said, you'll only find parts in a surplus place and that's if you're lucky.  May have to start replacing things and updating them to whatever you can find.
Update your "User Control Panel" (just below the upper teal bar) and enter your location and we'll be able to direct you to what is close to you.  Also you can add a signature block there also.
June 21, 2010, 01:55:29 PM
kb2ski
« Reply #3 on: June 21, 2010, 01:55:29 PM »
Wow,
You guys have it going on!  I appreciate the immediate feedback and I do realize this is going to be tough order to fill.  I just took several photos of the boat and will upload them soon.  I have a ton of photos and various aspects of the boat. Most I have seen have bimini tops.  Mine has a hard top.  It needs work but I am determined to get it ready for Rock fishing in the fall.  I am in the Urbanna, Virginia area and fish the Chesapeake Bay.
