Author Topic: motor getting stuck in up postion  (Read 729 times)
June 16, 2010, 04:59:17 PM
Read 729 times
aqua719
« on: June 16, 2010, 04:59:17 PM »
the trim seems like it is sticking going up and getting stuck going down with out a little help ( leaning on it )
maybe low on fluid or needs to be replaced?
any advice?  :scratch:
June 16, 2010, 05:03:20 PM
Re: motor getting stuck in up postion
« Reply #1 on: June 16, 2010, 05:03:20 PM »
I have seen that caused simply by corrosion/lack of grease on the tilt tube.
June 16, 2010, 05:07:32 PM
aqua719
« Reply #2 on: June 16, 2010, 05:07:32 PM »
Quote from: "John Jones"
going to start by cleaning it down, checking the fluid, lubing it up etc. hopefully that will solve the problem
June 16, 2010, 06:02:28 PM
« Reply #3 on: June 16, 2010, 06:02:28 PM »
If it's low on fluid the pump will sound like it is pumping pea gravel.
