Engines & engine woes
motor getting stuck in up postion
Topic: motor getting stuck in up postion (Read 726 times)
June 16, 2010, 04:59:17 PM
Read 726 times
aqua719
June 16, 2010, 04:59:17 PM »
the trim seems like it is sticking going up and getting stuck going down with out a little help ( leaning on it )
maybe low on fluid or needs to be replaced?
any advice?
June 16, 2010, 05:03:20 PM
Re: motor getting stuck in up postion
June 16, 2010, 05:03:20 PM »
I have seen that caused simply by corrosion/lack of grease on the tilt tube.
June 16, 2010, 05:07:32 PM
aqua719
June 16, 2010, 05:07:32 PM »
Quote from: "John Jones"
going to start by cleaning it down, checking the fluid, lubing it up etc. hopefully that will solve the problem
June 16, 2010, 06:02:28 PM
June 16, 2010, 06:02:28 PM »
If it's low on fluid the pump will sound like it is pumping pea gravel.
