Author Topic: 17' 1975 Need Gas Tank Dimensions and input on my rebuild  (Read 1680 times)
June 15, 2010, 09:23:16 PM
Read 1680 times
17.75
« on: June 15, 2010, 09:23:16 PM »
Just starting a renovation on my boat. Ill get some pics up before I rip out the floor. Going to need some help here. Never done this before. Reading about all of your renovations do not count right? I have a shopping list and need some input on it. I live in NY and keep the boat back home in South FL. I am flying out at the end of the month. I have 6 weeks to work/play on the boat.
Boat drawings/plans
http://s805.photobucket.com/albums/yy33 ... 0drawings/
Background on boat. My dad bought it from a neighbor (original owner) back in 1980. Boat has been sunk 2 times at side of sea wall behind house for short periods only. My brother had it after my dad and then my sister before I got it. So used hard for first 20 years and probably only 20 hrs in last 10 years. Had some work done on the engine and there was some termites found by my mechaninc who was looking into the soft spots (2) on the original floor as well. Had the boat tented last time I was down.
Plan started out just fixing the floor. Wife told me to make it last another 30 years to give to my kids. So here goes the floor, gas tank, wire, lights......everything basically. So as soon as the kids go off to camp. I get to go work with fiberglass durring a FL summer.
Quantaty   size   $$$      #   description/notes
1   month   350   350      marina/boatyard/workspace
1   ?   350   350      25-29 gal alluminum gas tank with sending unit 2 week delivery window,,,atlantic costal NJ 18004348265
5   4x8x3/4   69.99   349.95   OV  Item # 76126   Marine plywood for deck and new extension on casting deck w/storage
3   4x8x3/8      0      Shelving and subfloor
1   ?      0      Fiberglass need estimate on amount needed as well
1   ?      0      Epoxy/resin  need estimate on amount needed as well
1   est 150 cubic feet      0      Foam for (boat and cooler?)  need estimate on amount needed as well
26   1.5"   7   182   overtons   Stainless Steel Hinges  4 hole for replacement and new storage
1   3/4" hose   2.99   2.99   OV Item # 71787   drain for cooler
2   0.1 gal   17.99   35.98   OV Item # 79833   tubes hole sealant
1   6"   29.99   29.99   OV Item # 35042   distributor wires
1   led   39.99   39.99   OV  Item # 73513   light for bow
1   led   59.99   59.99   OV Item # 73529   light for stearn
2   17"x10"   12.99   25.98   OV Item # 75867   battery holders
1   1000gh   39.99   39.99   OV Item # 27397   new builge pump
1         0      2nd battery
1   ?   80   80      live well buy or build
1         0      bimini top contact chris or order new one
1         0      dive ladder/platform
8   90 deg   2.5   20   HD  Model C4807-LT   pvc/conduit for wires/cables
1   8oz/8oz   8.05   8.05   HD  Model 30248     pvc glue and pvc primer
7   10'x2"   5.15   36.05   HD  Model PVC 07200 0600   pvc/conduit for cables and 3 rod holders
2   10'x1"   2.7   5.4   HD  Model PVC 04010 0600    conduit for wire
6   2"   1.1   6.6   HD  Model 447-020HC    Caps for rod holders
110   4x25mm   0.9   99   HD Model 71528    SS bolts
110   4mm   0.48   52.8   HD Model 00168    SS nuts
110   4mm   0.58   63.8   HD Model 44838   SS lock washers
110   4mm   0.41   45.1   HD  Model 01218    SS washers
1   belt   34   34   HD  Model ZRBE318    sander buy/rent
1   55 gal   29.97   29.97   HD  Model RCP 8632-92 GRA      garbage can
1   50'   28.49   28.49   HD  Model 56754122    lights wire
1   2"   13.99   13.99   HD 7006   hole saw for drill
1   1"   7.49   7.49   HD 7002   hole saw for drill
thx
for any input
Note Prices Are High...I can get the stuff at Wholesale just using these prices so that when I come in underbudget I might be able to get the Jackplate I want.
June 16, 2010, 05:12:25 AM
Re: 17' 1975 Need Gas Tank Dimensions and input on my rebuild
« Reply #1 on: June 16, 2010, 05:12:25 AM »
Welcome aboard 17.75  :!:  :!:
Looks like you have a fuel tank on the list - you going to carry one down on the airplane with you or do you want to find one down here?  SB4 might have the contacts that know the dimensions of a '75 170 fuel tank.  SB4 to the white phone.
June 16, 2010, 03:23:01 PM
« Reply #2 on: June 16, 2010, 03:23:01 PM »
Everything will be shipped to my Mother-in-Laws or purchased in the South Florida area. I looked on the Members list and did not see a SB4....is that shorthand for a members name?
thx
June 16, 2010, 08:34:01 PM
« Reply #3 on: June 16, 2010, 08:34:01 PM »
SeaBob4
June 16, 2010, 09:41:33 PM
« Reply #4 on: June 16, 2010, 09:41:33 PM »
Rick,
He sent me a PM, I sent him one back saying I need dimensions.  Haven't heard back, yet he said he needs it ASAP...
Kinda like Skip, who I got a damn good price for, and haven't heard back...
I contact Ray, he goes through the motions he has to go through, get the quote, and then...bam!  They're gone!  That's Bullsh!t!  I'm doing this as a service to the members, and I ain't to real f****** pleased right now!
Sorry to rant, I love the members here, maybe my priorities are in the wrong place.  Just wanted all to know I contacted him.  To me, ASAP means ASAP!
June 16, 2010, 11:39:17 PM
« Reply #5 on: June 16, 2010, 11:39:17 PM »
Bob try not to get to upset or discouraged,if you do i can't blame you, but for every one guy like that (and i know you know this) there are a bunch of us who really appreciate your efforts.
June 17, 2010, 12:59:53 AM
« Reply #6 on: June 17, 2010, 12:59:53 AM »
Bob sorry you feel that way and that you misuderstood my original request. As noted in the title and as mentioned in my PM I am looking for the dimensions how could I give them to you.
As I mentioned at the bottom of my orginal post. I have all the conections to get the things I need at below wholesale. I am and never was looking for a quote....just some friging dimensions and another opinion on my redo.
And yes Bob ASAP means ASAP to me as well (I leave in 2 weeks and there is a 2 week turnaround from the tank company, I will be needing the tank 2-4 days after I land that gives me 2 more days to get the dimensions).
My childhood friend is a Retired Captin and has done 7 redos on boats 15-25 feet. But if getting info or a second opinion on my Aqua redo is causing so much flack.
Then BOOT ME!!!
I don't care for people who air thier griefs in a public forum. Especially when they are wrong. Bob hope you can blame your rant on having a bad day.
Nice way to treat a new member who has had an Aqua in his life for 30 years.
June 17, 2010, 05:46:55 AM
« Reply #7 on: June 17, 2010, 05:46:55 AM »
So I guess the bottom line is, and what his original question was - does anyone have the dimensions for a 75 170's fuel tank?  I figured someone would, otherwise I would not have told to him to query the membership.
Hope everyone can take a deep breath, calm down and realize what is being requested here.  He doesn't want a quote - he wants to know if anyone has dimensions so he can get his tank built.  The tank guy in Jersey (or someone up there, what's his name?) probably has the dimensions and will build the tank for you too.  Probably won't just give you the dimensions though.
June 17, 2010, 07:20:03 AM
Miguel
  • Panama
« Reply #8 on: June 17, 2010, 07:20:03 AM »
Here is the one I had built for my 1985 170. It's made of 1/8" marine aluminum plate, the coal tar epoxy coated.
L = 57.5"
W = 20.25"
H =6.125"
Hope this helps.
Miguel
[/url]
June 17, 2010, 11:14:17 AM
« Reply #9 on: June 17, 2010, 11:14:17 AM »
17.75,
Yeah,I didn't have the best of days yesterday.  My apologies.  I can get a pretty damn good price from RDS a they will sell it to me at what Pro-Line would pay for it.  I make a little money, you get a good deal, and RDS gets a little business.
But if you have a tank guy who can give you a good deal and a quality product, then by all means utilize him!  Sorry I can't be of more help with the dimensions, but even Wellcraft CS doesn't have them.
Good luck with the re-build!  Once again, my apologies...
Bob
June 17, 2010, 06:29:18 PM
« Reply #10 on: June 17, 2010, 06:29:18 PM »
Thx Meguel.. Was the 1985 built in FL or after? Worried about the difference of 10 years in boat design.
Bob I have been there no problem.
June 17, 2010, 06:37:50 PM
Miguel
  • Panama
« Reply #11 on: June 17, 2010, 06:37:50 PM »
Hialeah, FL. :D
Miguel
[/url]
June 18, 2010, 05:36:50 AM
« Reply #12 on: June 18, 2010, 05:36:50 AM »
The Aquasports were always built in FL - first 20+ years in Hialeah and then in Bradenton (probably had a Sarasota address though) 'til the end.
