Engines & engine woes
Check Engine Light
Topic: Check Engine Light (Read 1020 times)
June 07, 2010, 04:57:39 PM
Read 1020 times
fabuck71
Check Engine Light
June 07, 2010, 04:57:39 PM »
I have a 1998 225 johnson ocean runner, and the check engine light came on. Waterpump is new, thermostats new, water seperator is new, in-line fuel filter new (All Replaced this weekend), and the engine runs fine. Any ideas? The only one I have is the hour meter just turned 400 and maybe its like a car, like the pre-programmed 30K BS miles light? If so does anyone know how to turn it off besides placing a black piece of tape over it
? Or maybe its a low gas thing?
Boat is pretty new to me.
Alex Buck
Bass Underwriters of Florida
800.528.5386
June 07, 2010, 06:08:02 PM
Re: Check Engine Light
June 07, 2010, 06:08:02 PM »
Sounds like a fuel restriction problem. Could be trash in a line or somehow line got pinched.
Of course it could be like you said and be an "idiot" light.
June 07, 2010, 08:18:37 PM
labboss2003
June 07, 2010, 08:18:37 PM »
oil pickup?????? just one more thing to check
June 07, 2010, 09:10:10 PM
Rigging Master
June 07, 2010, 09:10:10 PM »
Did the engine start to run any differently before the idiot light came on? On your "System Check", you've got "low oil", and "no oil", and neither of those lights came on. You've got a good pisser stream...
PM Seahorse over on THT. That man is an OMC guru...if you're not a member, I'll do it for you.
June 07, 2010, 09:35:59 PM
June 07, 2010, 09:35:59 PM »
I know my '93 Ocean Runner had an alarm for fuel flow restriction. I think it was a vacuum switch. I let my manuals go with the boat.
June 07, 2010, 10:22:54 PM
fabuck71
June 07, 2010, 10:22:54 PM »
I've read a lot about the fuel restriction so I will check that first. I have also read about the vacum switch. I'll pick up my manual tomorrow and hopefully it will help. The light comes on and stays on even in the on position before starting. Water pump and everything cooling related is new so not a water issue.
Alex Buck
800.528.5386
June 08, 2010, 11:03:46 PM
June 08, 2010, 11:03:46 PM »
On my boat i have a fuel diverter valve to switch fuel from the main to the kicker, and if it's on the kicker and i start the main the check engine light comes on,switch it back and all is fine,so low fuel pressure is my guess,check the fuel line as it goes into the motor,where it and all the cables run through that plastic boot,i once had my oil line pinched in there and didn't know it till the no oil light came on.
June 10, 2010, 04:01:10 PM
fabuck71
June 10, 2010, 04:01:10 PM »
Ended up being a faulty vacum switch,
Alex Buck
800.528.5386
June 10, 2010, 06:26:11 PM
June 10, 2010, 06:26:11 PM »
Check Engine Light
