Author Topic: Rewiring 245  (Read 2026 times)
June 04, 2010, 11:49:57 AM
Read 2026 times
Mark Sr
Rewiring 245
« on: June 04, 2010, 11:49:57 AM »
Having some electrical issues and was wondering what is the best way to tackle a rewiring job.Should I do just one wire at a time?Any diagrams for dummies around?
Mark Sr
June 04, 2010, 01:05:34 PM
Re: Rewiring 245
« Reply #1 on: June 04, 2010, 01:05:34 PM »
Mark,
I would recommend making up a harness.  Go to the wiring chart on the Wellcraft page here, http://www.wellcraft.com/#/21/ to get the proper colors.
Now here are 2 diagrams that I have drawn up that, although they don't mimic your boat exactly, give you a basic idea of how the bilge area and helm switch panel is wired...
Obviously you won't have a plug, as the original is part of the old wiring and probably should get tossed, but you really don't need one.
Any questions, let me know...
June 04, 2010, 01:22:41 PM
Mark Sr
Re: Rewiring 245
« Reply #2 on: June 04, 2010, 01:22:41 PM »
Great job Seabob.How about different guage wires.What guage for what areas.
Mark Sr
June 04, 2010, 01:39:29 PM
cdoyal
Re: Rewiring 245
« Reply #3 on: June 04, 2010, 01:39:29 PM »
Quote from: "Mark Sr"
14 gauge should do for most things except the 12v feed and your ground to the bus bars. Don't forget to use heat shrink connectors. That's the key.
1997 245 Explorer w/225 Johnson Ocean Runner
June 04, 2010, 01:57:46 PM
Re: Rewiring 245
« Reply #4 on: June 04, 2010, 01:57:46 PM »
Quote from: "cdoyal"
Chris is right on the 14GA.  You can get by with 16, but I'll take 14.  The feed for the helm, both hot and ground, should be 8GA.  And absolutely on the heat shrink sleeving...
Here's a great place to get wire and cable...genuinedealz
June 04, 2010, 02:09:42 PM
Re: Rewiring 245
« Reply #5 on: June 04, 2010, 02:09:42 PM »
Mark,
I tried attaching the drawings in PDF form here but the site won't let me... :(
So if you go here...http://www.theprolineguy.com/electrical-drawing-pdfs-t127.html, you can download the drawings as PDFs, makes them easier to save and print... :thumright:
June 04, 2010, 02:40:17 PM
Mark Sr
Re: Rewiring 245
« Reply #6 on: June 04, 2010, 02:40:17 PM »
I got the drawings.They are great and thanks for taking the time to post them.Now I just need a cloudy cold spell to keep the nats away.
Mark Sr
June 04, 2010, 02:50:58 PM
Re: Rewiring 245
« Reply #7 on: June 04, 2010, 02:50:58 PM »
Mark,
Noticed your other locale is New Gretna.  Been by the Viking plant lately?
June 04, 2010, 02:54:14 PM
Mark Sr
Re: Rewiring 245
« Reply #8 on: June 04, 2010, 02:54:14 PM »
No Bob,my slip faces Viking.I use to know guys that worked in there years ago.Alot of money in those slips.I couldn't even afford the gas.Nice boats.
Mark Sr
June 04, 2010, 02:59:30 PM
Re: Rewiring 245
« Reply #9 on: June 04, 2010, 02:59:30 PM »
I couldn't afford to change the oil in those 2000HP diesels... :shock:
June 04, 2010, 03:59:11 PM
JoseGaspar
Re: Rewiring 245
« Reply #10 on: June 04, 2010, 03:59:11 PM »
Agree with SeaBob on genuinedealz.com.  I just did a major rewire of my 250 CCP and got all of my wires and connectors from them.  Great material....cheap.
JG
June 04, 2010, 04:21:42 PM
cdoyal
Re: Rewiring 245
« Reply #11 on: June 04, 2010, 04:21:42 PM »
Ditto genuinedealz.com. They are the best.
June 05, 2010, 12:12:20 PM
Mark Sr
Re: Rewiring 245
« Reply #12 on: June 05, 2010, 12:12:20 PM »
Thanks for all the help
Mark Sr
June 09, 2010, 04:50:02 PM
Mark Sr
Re: Rewiring 245
« Reply #13 on: June 09, 2010, 04:50:02 PM »
On the 14 guage wire,is there a difference between 14 guage you can buy at Home Depot etc. or is marine wire different.Does marine wire have  different insulation?
Mark Sr
June 09, 2010, 05:08:50 PM
cdoyal
Re: Rewiring 245
« Reply #14 on: June 09, 2010, 05:08:50 PM »
Yes, there's a big difference. Marine wire is tinned. In regular wire, the copper is bare and more prone to oxidation. Order 100' of red, brown, and black from genuinedealz.com and you'll be well on your way.
