They say its your legs that are first to go but my memory left me long before my running days ended.It's great speculation though. You never really know until you open her up.We've seen so many "discrepancies" from the norm on the Hialeah hulls, either from factory effects or previous owners handy work.And while the Genmar group seems to follow a pretty set pattern of construction, there, every so often, seems to be that little "twist" that makes ownership a slight challenge and yet a delight.
Front hold area not draining.Hozenya, did you every solve the mystery of why the water would not drain the the rear bilge? I have the same issue. No water will exit the front compartment or fuel tank compartment threw the rear drain. I need to pump it out with the font bilge pump. It seems like if should just run out the aft bilge by the angle I have it on. I to put the rod threw the pvc drain and hit the tank. Any help would be appreciated.
