Understood, my thought process was to use a camcorder and look from under the bait tank to see if that is where the obstruction is.On a side note, I think I read in another posting that the deck inside the CC area where all the cables run through you can place a larger opening/hatch? Will this help is 'seeing' inside the cavity area where the drain runs from the bow area?Just a thought.
Update on the water not flowing from the forward comparment;Ran a glass rod from the front compartment and was able to 'hit' what seems like the aft bulkhead in the fual coffen. Ran the same rod from the aft exit hole at the fual coffen and could hear the rod hitting hte underside of the fuel cell. But the water just sits in the forward compartment, best guess now is the boat is leaning forward and the water is not able to flow aft.Will update more once I move the boat to see if that resolves the flow issue.
