Author Topic: bottom plug  (Read 945 times)
May 13, 2010, 05:11:55 PM
Read 945 times
jdevoid
bottom plug
« on: May 13, 2010, 05:11:55 PM »
I have a 2001 225 EX-  I put the bottom plug in very tight and noticed that 2 to 3threads are showing. Is is ok that the plug doesn't thread all the way in?
May 13, 2010, 05:50:49 PM
Re: bottom plug
« Reply #1 on: May 13, 2010, 05:50:49 PM »
Is there an O-ring at the base of the drain plug?  If not, there needs to be... :thumleft:
May 13, 2010, 05:55:29 PM
Re: bottom plug
« Reply #2 on: May 13, 2010, 05:55:29 PM »
Its a brass pipe (taper) thread. Make sure the threads are not full of sand or debris. Its ok to have some threads showing. In fact, its better to have some threads showing that ensures the taper is locked in. I clean mine occasionally and put a dab of grease on it to keep the threads smooth and undamaged.
Fitz
May 13, 2010, 06:01:30 PM
Re: bottom plug
« Reply #3 on: May 13, 2010, 06:01:30 PM »
Sorry Seabob,
Didnt mean to step on your toes! I forgot it may have the finger tight version that needs the O-ring... A thousand pardons! I`m thinking about my old 73 that needs the 9/19 wrench to tighten.
May 13, 2010, 06:07:13 PM
Re: bottom plug
« Reply #4 on: May 13, 2010, 06:07:13 PM »
Quote from: "fitz73222"
Sorry Seabob,
Fitz,
My toes are very resilient!  You have the old "square head" plug, one I love, find nothing wrong with it.  But I'm pretty sure jd's is the hand version, although I still put a leatherman on it when I tighten her up...
And BTW, you've got to tell me where I can get one of those 9/19" wrenches from, I've been looking for one for ages! :shock:  :shock:
May 13, 2010, 06:22:02 PM
Re: bottom plug
« Reply #5 on: May 13, 2010, 06:22:02 PM »
OK, OK, OK, 9/16" . I was going to print a retraction! But what the hell. It`s been a long day...
May 13, 2010, 06:29:40 PM
Re: bottom plug
« Reply #6 on: May 13, 2010, 06:29:40 PM »
Or if you prefer please hand me the 0.562" or the 14.2748mm wrench!!! So There....
May 13, 2010, 06:36:20 PM
Re: bottom plug
« Reply #7 on: May 13, 2010, 06:36:20 PM »
May 13, 2010, 06:36:41 PM
Re: bottom plug
« Reply #8 on: May 13, 2010, 06:36:41 PM »
Thats why I carry an adjustable....
May 13, 2010, 06:38:56 PM
Re: bottom plug
« Reply #9 on: May 13, 2010, 06:38:56 PM »
An unfortunately necessary evil... :shock:
May 13, 2010, 06:49:33 PM
Marcq
Re: bottom plug
« Reply #10 on: May 13, 2010, 06:49:33 PM »
You can tell when they go  bad, when no threads are showing anymore. And you don't want to over tight them, I have the tendency to do that
Marc..
May 13, 2010, 07:47:36 PM
jdevoid
Re: bottom plug
« Reply #11 on: May 13, 2010, 07:47:36 PM »
Thanks all.
I did put grease on it and used an adjustable.  Do I still need an o-ring though?  I do believe it is the brass tapered plug
May 13, 2010, 07:53:37 PM
Re: bottom plug
« Reply #12 on: May 13, 2010, 07:53:37 PM »
Quote from: "jdevoid"
Thanks all.
Tapered threads (NPT)?  Nope, the plug will never even get close to flush...
