Author Topic: Need Help Finding Part  (Read 914 times)
May 11, 2010, 07:46:53 PM
Read 914 times
Mark Sr
« on: May 11, 2010, 07:46:53 PM »
For all you guys who live in Flordia I need your help.I know you guys talk about Aquasport surplus places.I need a livewell wash down valve for my 98 Tournament Master.The one I have is all corroded and my son broke it taking it off.I'll try to post these pics hoping someone knows where to get one your have a better solution.
Mark Sr
May 11, 2010, 08:00:20 PM
Re: Need Help Finding Part
« Reply #1 on: May 11, 2010, 08:00:20 PM »
...and after all that work to thru-bolt her in there!  Mark, you may not realize, but I installed that valve!  And now it sits, rotting, corroding, and broken, on a bench top...OK, I'm over it!  It's a Bosworth valve, you can still get them at Worst Marine, but Circle Hooked had good luck at Marine Surplus down here...I think.  What part broke?
May 11, 2010, 08:17:50 PM
« Reply #2 on: May 11, 2010, 08:17:50 PM »
Bob your right,and is it me or is this starting to be a common problem here and on your site,i lost count.
Mark plan on spending about 40-50 bucks for a new one,as boats go i guess thats cheap though,heres the link for worst marine http://www.westmarine.com/webapp/wcs/st ... &langId=-1
May 11, 2010, 08:32:40 PM
Mark Sr
« Reply #3 on: May 11, 2010, 08:32:40 PM »
I was at worst marine today in South Jersey and they said they have nothing like it,but I did see it on there site.Bob,it was just corroded so bad that we couldn't even budge it.My son drilled the screw off the handle but the corrosion was so bad I still can't get it out of the face plate.Everything was plastic except for the handle.Thanks for the info.Circled Hook thanks also.
Mark Sr
Mark Sr
May 11, 2010, 08:39:35 PM
Mark Sr
« Reply #4 on: May 11, 2010, 08:39:35 PM »
Bob,
Do you know what size the valve was.As you see in pics the hose ends are probably glued in.What size in the female part on the valve?Is it standard on the Aqua's.
Mark Sr
Mark Sr
May 11, 2010, 08:48:24 PM
« Reply #5 on: May 11, 2010, 08:48:24 PM »
Mark you have a 3/4 inch model,and thats the size of the ends,if you look hard the end should have 3/4" stamped on them.
May 11, 2010, 08:49:07 PM
« Reply #6 on: May 11, 2010, 08:49:07 PM »
Mark,
Funny you should say that, I was going to tell you the handle is removable...in fact I used to have to disassemble that valve to t/bolt it to the inside of the tackle storage center.
The barbs are 3/4" thread with 3/4" barbs for the hoses.  Simply screwed in with a bit of pipe dope on the threads.  Since the valve is toast, put it in a vise, and you should be able to remove them and use them on the new one...
Scott, your right, a lot of livewell/washdown issues showing up...also fuel senders and electrical issues.  I think it's just the spring time up north, people using their boats again, karma, and nobody's got the bucks to replace their 10-12 year old boat with a new one...
May 11, 2010, 08:54:13 PM
« Reply #7 on: May 11, 2010, 08:54:13 PM »
Mark,
You hit the nail there
May 11, 2010, 09:02:32 PM
Mark Sr
« Reply #8 on: May 11, 2010, 09:02:32 PM »
All the ones I see on the internet show no threads,just smooth inside like a glue joint.
Mark Sr
May 11, 2010, 09:18:31 PM
« Reply #9 on: May 11, 2010, 09:18:31 PM »
The one you want is the top center one...
Now just have to find it... :scratch:
May 11, 2010, 09:28:25 PM
« Reply #10 on: May 11, 2010, 09:28:25 PM »
Give these guys a call...http://www.sandiegomarine.com/BOS-94-A- ... /prod/1123
Just make sure the ports are tapped, even though it says so...
May 12, 2010, 10:30:08 AM
Mark Sr
« Reply #11 on: May 12, 2010, 10:30:08 AM »
I called Bosworth direct and they got me the one I need at $53.45.Here's there site if anyone is in need of one.
www.thebosworthco.com
Mark Sr
May 12, 2010, 10:32:01 AM
« Reply #12 on: May 12, 2010, 10:32:01 AM »
Quote from: "Mark Sr"
Well done, Mark! :cheers:
