I have a 98 Tournament Master 225hp.I put new end caps on my teleflex 5345 cylinder today.Bled the system and everything.When it's all said and done,you should not be able to turn motor by hand,correct?Are there any check valves in the helm? Does anyone know what helm is used?The only info I could get off the helm was:seastar 1.76.9 mpa1000 psi maxNeed help.ThanksMark Sr
