Electrical
Ignition Switch Wiring
Topic: Ignition Switch Wiring (Read 3753 times)
May 08, 2010, 12:15:00 PM
nightrain76
Re: Ignition Switch Wiring
Reply #15 on:
May 08, 2010, 12:15:00 PM »
to connect the instruments could i use the samebrown wire that goes also to the buzzer???
May 08, 2010, 12:19:58 PM
Marcq
Reply #16 on:
May 08, 2010, 12:19:58 PM »
Not sure if the temp instrument uses the same sensor
edit:After checking around, you need a different sensor
Marc..
August 09, 2010, 05:58:17 PM
nightrain76
Reply #17 on:
August 09, 2010, 05:58:17 PM »
hello,now i've got another problem ,i conected the brown cable and the violet cable to the buzzer,but wich is eh cable that i have to connect to the signal o the water temp. instruments???????????thank you
Electrical
