Author Topic: Ignition Switch Wiring  (Read 3752 times)
May 03, 2010, 05:40:57 PM
Read 3752 times
nightrain76
« on: May 03, 2010, 05:40:57 PM »
Hi,i write you from Italy,i'm trying to rebuild my 17" aquasport,i've got a 1974 115cc johnson,someone of you knows which are the color and when i hav to connect to the Ignition Switch Wiring??????thank's Giordano
May 03, 2010, 06:02:46 PM
May 04, 2010, 09:52:11 AM
Marcq
Re: Ignition Switch Wiring
« Reply #2 on: May 04, 2010, 09:52:11 AM »
And make sure you have the right switch, when I replaced mine I bought the wrong one even though it was suppose to be the replacing part number
Marc..
May 05, 2010, 01:36:54 AM
nightrain76
« Reply #3 on: May 05, 2010, 01:36:54 AM »
unfortunately i've only 5 position
M
S
A
M
B
but i have 8 wires......
May 05, 2010, 09:52:14 AM
Marcq
« Reply #4 on: May 05, 2010, 09:52:14 AM »
Quote from: "nightrain76"
M
S
A
M
B
Just realize your motor is a 1974(didn't have a safety switch in that year)
M- (left side) black/yellow18ga(from the red plug)
S-white 18ga(comes from the neutral start switch which the white(from the red plug) is connected to
A-  purple18ga(comes from the choke switch which the purple/white18ga(from the red plug)is connected to . There's also a jumper lead purple 16ga that comes from the horn which a tan wire 18ga (from the red plug) is connected to
M-(right side) two black wires, 16ga that comes from the red plug, 18ga from the ground lead of the controls
B-red/purple12ga from the red plug
Now you should have a gray wire18ga, it's the tach lead
Lets see how it goes, we will get you running soon
Marc..
May 05, 2010, 11:26:23 AM
nightrain76
« Reply #5 on: May 05, 2010, 11:26:23 AM »
than if ihave understand well i've to connect the red with violet stripes to B,the grey one directly on the tachometer,the white one to S,the brown one to A,the black with yello stripes to M,the black one to the other M,but now i have one violet and one violet with white stripes???????sorry but i would like to understand well,thank's for all
May 05, 2010, 12:31:43 PM
Marcq
« Reply #6 on: May 05, 2010, 12:31:43 PM »
the brown one to A
The brown should be connected to the horn (alarm,buzzer, in case your motor overheats) and a purple wire(jumper) from the horn to the A. You do have a horn?
The violet with white stripes goes to the choke switch and from there to the A and the other violet can go directly to A if you want.If you want to choke your motor the violet with the white stripe needs to be connected to the choke switch
Hey Giordano, no problemo  :) .don't be afraid to ask, you are almost there :)
Marc..
May 05, 2010, 05:21:54 PM
nightrain76
« Reply #7 on: May 05, 2010, 05:21:54 PM »
thank you again but i have some questions.......
1- i think that i don't have neutral start switch,is it possible???and so i have to connect directly white on position S???
2- i have the horn but i connect and control it by the panel on the side, the same panel where i control bilge pump,anchor light,navigation light ecc ecc...
3- i don't have automatic choke i have to pull the choke directly on the motor
4- i've got the buzzer and on the buzzer i have 2 wires haw can i connect it???
becouse i have a braid with 8 wires that cames from the motor and i have to connetc to the Ignition Switch Wiringsorry fro my bad english and thank's again
May 06, 2010, 05:17:05 PM
Marcq
« Reply #8 on: May 06, 2010, 05:17:05 PM »
Do you have any wires coming out of the control box(throttle control) your neutral switch should be in there
No, we are not talking about that horn ;)
It should part of your ignition switch, can you push your key in the switch?
One end to A and the other end to the tan or brown wire
BTW, what kind of controls do you have? Because the choke, neutral switch could  be in your control box!!
:) Marc..
May 08, 2010, 06:16:23 AM
nightrain76
« Reply #9 on: May 08, 2010, 06:16:23 AM »
1-I've got teleflex morse as control box and i don't find neutral start switch,
2-for the buzz i connect the brown wire that comes from the braid and from the atore wire that exit from the buzzer i connect to A???is correct??
3-i don't understand what i have to do with violet and violet with white stripes............ :?
thank's
May 08, 2010, 09:13:27 AM
Marcq
« Reply #10 on: May 08, 2010, 09:13:27 AM »
So you don't have wires coming out of the control box? from underneath ?
Yes
thank's
For now, just connect the purple wire to A
The purple/white wire is for the choke(it comes from the choke solenoid), you can add a switch later if you want by putting a momentary switch between the purple/white wire and A, you will then be able to choke your motor with that switch
Here's what the switch does when in action, you'll notice that on START position contact is being made from the battery to A and S, the wire connected to S goes to the solenoid to activate the starter, once the motor is running the ignition will be on the ON postion
Marc.. :)
May 08, 2010, 11:23:28 AM
nightrain76
« Reply #11 on: May 08, 2010, 11:23:28 AM »
the last question(i hope)
how can i connect the buzzer and the relative nstrument of water temperature?
May 08, 2010, 11:32:33 AM
Marcq
« Reply #12 on: May 08, 2010, 11:32:33 AM »
Not sure you can, the buzzer gets the signal from the temp switch/sensor that's on the engine
Marc..
May 08, 2010, 11:38:07 AM
nightrain76
« Reply #13 on: May 08, 2010, 11:38:07 AM »
and the instruments?
May 08, 2010, 12:12:39 PM
Marcq
« Reply #14 on: May 08, 2010, 12:12:39 PM »
Can't remember who made this or where I got it from but it should answer your question
Oh, don't forget to post pictures of your boat ;)
Marc..
