Author Topic: CCA's required to crank Suzuki DF140?  (Read 3946 times)
May 03, 2010, 11:29:21 AM
Read 3946 times
MarshMarlowe196
« on: May 03, 2010, 11:29:21 AM »
Hey guys-
I can't seem to find a clear answer to this question- hoping someone here could help me out.  Battery in my boat is done (and it's still relatively new  :x ).  Can anyone tell me what the recommended Cold Cranking Amps would be for a 08' Suzuki DF140??
Thanks  :salut:
Key West 1720 / Yam C90
Sold: 1973 Aquasport 19-6
May 03, 2010, 11:58:42 AM
Re: CCA's required to crank Suzuki DF140?
« Reply #1 on: May 03, 2010, 11:58:42 AM »
Hey Badonaquasport196,
My advice is to buy the biggest battery that will fit. Atleast a group 27 or 29 with atleast 875 CCA`s. If your battery is under the console and connected using some Size 0 or 1 cable for that 10 or so feet to the motor, I would get a 900-950 CCA. I have twin 115`s with batteries under the console with two 750 amp batteries that are barely enough with big clean size 1 cables. I`m switching to group 29 900CCA for the juice.
May 03, 2010, 04:45:07 PM
« Reply #2 on: May 03, 2010, 04:45:07 PM »
Quote from: "Badonquasport196"
Hey guys-
Thanks  :salut:
Jessie,
Been trying to download the DF140 Manual to no avail.  Anyway, I use an Excide Nautilus group 24, 1000 MCA, 800CCA.  Can't go wrong, takes care of Verados as well... :thumleft:
Bob
May 03, 2010, 08:07:18 PM
MarshMarlowe196
« Reply #3 on: May 03, 2010, 08:07:18 PM »
Hey guys-
Thanks  :salut:
Jessie,
Bob
Yeah I had the same problem  :?
I know it seems obvious that the more CCA's you have the better, but the problem I was running into was whenever I would find a battery that had more than around 600CCA's, it became very big (like the size of a deep cycle), and most of the batteries I found were dual deep cycle/cranking batteries.  I don't want a dual battery as I already have a dedicated deep cycle and the bigger batteries wont fit in my cranking battery box under the console.
Good news is I found an Interstate Marine cranking battery with 1000CCA's that's nice and small and fits perfectly in my battery box.  It was a tad pricey but it's exactly what I needed.  Problem solved :)
Thanks for the input guys  :salut:
May 03, 2010, 10:12:32 PM
« Reply #4 on: May 03, 2010, 10:12:32 PM »
How's your Dad doing?
May 03, 2010, 11:43:07 PM
MarshMarlowe196
« Reply #5 on: May 03, 2010, 11:43:07 PM »
He's good, and the market for boats here seems to continue to be on the upswing.  He stays very busy most of the time.
Here's a short local article if you're interested:
http://www.postandcourier.com/news/2010 ... les-droug/
How's the market on your side of town?
