22-2 Rebuilds
thru hull question fo you 22-2 guys
Topic: thru hull question fo you 22-2 guys (Read 1386 times)
September 21, 2005, 07:53:10 PM
Read 1386 times
OldSchool
September 21, 2005, 07:53:10 PM »
do any of you have a forward bilge thru hull, it is located 2' straight above the fish box drain, my questions is have any on you replaced it and also the fishbox drain thru hull....I'm looking to upgrade to stainless steel. thanks...
1998 Osprey 175 Evinrude 115
1996 Osprey 200 (sold)
1976 Straight Inboard 22-2 (sold)
September 22, 2005, 08:16:09 AM
g-man
September 22, 2005, 08:16:09 AM »
That must be a feature for the inboard and i/o 222's. I don't ever recall seeing a bilge pump in an original o/b 222.
1973 22-2(gone but not forgotten...see fitz73222 to follow her wake)
G-whizz
September 22, 2005, 08:44:52 AM
Tailgunner
September 22, 2005, 08:44:52 AM »
I have one in mine and somebody else replaced it with what appears to be HD garden hose. I don't use it as a fish box but rather for anchor and life jacket storage.
Tailgunner
Now in BroadBill\'s hands
September 22, 2005, 09:42:56 PM
OldSchool
September 22, 2005, 09:42:56 PM »
thanks guys,
tailgunner I have the same green garden hose, looks like the factory did that back in 76
September 26, 2005, 10:04:14 AM
DEFIANT
Guest
September 26, 2005, 10:04:14 AM »
My 1983 222 has the thru hull fitting. It was used to drain the above deck fish box. I removed the above deck box so there is no need for it.
When I rebuilt my front deck I enlarge the below deck fish box and insulated it with foam so I could carry five - five gallon buckets of shark chum. I located a pump below a deck plate I installed in front of the console and utilized the old thru hull fitting. This made it possable to pump out the box. I must admitt I very rarely use the pump since I found no need to put ice in with the chum buckets, they stay plenty solid.
The original set up drained the box into the bilge.
By the way there is room between the stringers in front of the console for a spare fuel tank. I put a 28 gallon reserve tank there. The forward weight seems to help preformance.
22-2 Rebuilds
