Author Topic: Tilt Problem  (Read 856 times)
April 14, 2010, 10:13:18 PM
Read 856 times
cdoyal
Tilt Problem
« on: April 14, 2010, 10:13:18 PM »
I'm having trouble with the tilt on my 97' Ocean Runner 225. It started slowing down and making a grinding sound. Others have said it sounds like there's air bubbles in the line. Is this possible? How do I bleed the line?
Thanks,
Chris
1997 245 Explorer w/225 Johnson Ocean Runner
April 14, 2010, 10:41:58 PM
Re: Tilt Problem
« Reply #1 on: April 14, 2010, 10:41:58 PM »
Have you checked the fluid resivor,tilt the motor up engage the tilt lock then look for a black plastic cap,should have a slot on top that a flat head screw driver will fit into,the seals on mine were bad and topping off the fluid bought me over a year of use before replacing.
April 14, 2010, 11:11:14 PM
cdoyal
Re: Tilt Problem
« Reply #2 on: April 14, 2010, 11:11:14 PM »
Quote from: "Circle Hooked"
I'd like to do that but I can't raise the motor. The manual release screw is frozen too. I'll shoot some PB Blaster in there and see if I can't break it loose.
April 14, 2010, 11:33:50 PM
Re: Tilt Problem
« Reply #3 on: April 14, 2010, 11:33:50 PM »
Hate to say it but you sound like your where i was at when i replaced everything.
April 15, 2010, 03:05:57 AM
Re: Tilt Problem
« Reply #4 on: April 15, 2010, 03:05:57 AM »
Try "helping" the engine tilt up with someone or a come- a- long attached to the gearcase and pull up on the gearcase while you engage the up button and try to tilt up the engine. Also check all the electrical connections and battery voltage to make sure that isnt part of the problem. Hopefully the system does not have water in it. If it has air in the system you should hear the pump cavitating and a whining sound. Normally if you have air in the system you will see a fluid leak out of the trim ram piston(s).
Fitz73222
April 23, 2010, 02:47:39 PM
cdoyal
Re: Tilt Problem
« Reply #5 on: April 23, 2010, 02:47:39 PM »
Yeah, I just got a quote that it's $1150 to replace the whole assembly which they say is shot due to corrosion. The ground wire bolt sheared off and it took them quite a while to unseize the manual release bolt. All seals were leaking. Now, to break the news to my wife. It will be most unpleasant.
April 23, 2010, 09:35:54 PM
Re: Tilt Problem
« Reply #6 on: April 23, 2010, 09:35:54 PM »
Ouch!  Shop around and you can buy the entire outboard for that much $$.
April 23, 2010, 09:40:31 PM
cdoyal
Re: Tilt Problem
« Reply #7 on: April 23, 2010, 09:40:31 PM »
Quote from: "John Jones"
A reliable 225 for $1100? I think not.
April 23, 2010, 11:34:55 PM
Re: Tilt Problem
« Reply #8 on: April 23, 2010, 11:34:55 PM »
OK
