Author Topic: Dimensions for a 19-6 50gallon gas tank?  (Read 672 times)
March 14, 2010, 10:11:09 PM
Read 672 times
75classic
« on: March 14, 2010, 10:11:09 PM »
Does anybody have the exact dimensions for a 19-6 50 gallon gas tank? Im in the market for a new one and want to get the right size. thanks
Brandon
March 15, 2010, 08:12:50 AM
Re: Dimensions for a 19-6 50gallon gas tank?
« Reply #1 on: March 15, 2010, 08:12:50 AM »
This is who you want in your area.
viewtopic.php?p=33591#p33591
You didn't say what year (but your user name does suggest a 75) :idea:  so read the whole thread. This is a recent 19-6 replacement, circa 1975
Skoot probably has the dims. you seek.
March 15, 2010, 09:04:26 AM
Skoot
« Reply #2 on: March 15, 2010, 09:04:26 AM »
Yup, those dimensions are accurate to an original 1975 50 gallon tank. My new tank is currently in production, just got the drawings from RDS today.  I did slightly modified the original tank height to an even 8". This made the tank 45gallons instead of 50gal.  The reason I did this was because the old tank was laying flat on plywood and it only left about 1/4" of clearance from the top of the fill and vent tubes to the bottom of the hatch cover.  I plan on raising it off the plywood to allow air flow and I didnt want to run into problems with the cover hitting the top of the tank.
I would try to get a hold of seabob4. He hooked me up, and might be able to do the same for you. :cheers:
1975 19-6 - 90hp Tohatsu
March 15, 2010, 04:19:57 PM
75classic
« Reply #3 on: March 15, 2010, 04:19:57 PM »
thanks for the info :thumleft:  I apologize for not give the year of the boat.
brandon
