Author Topic: new floor  (Read 750 times)
March 09, 2010, 09:24:46 PM
Read 750 times
aquasport
new floor
« on: March 09, 2010, 09:24:46 PM »
before laying the new floor in , should i glass the side of the interior hull to the finished glass panel on each side of the hull. 222 flatty
March 10, 2010, 08:15:42 AM
dbiscayne
Re: new floor
« Reply #1 on: March 10, 2010, 08:15:42 AM »
'the finished glass panel'
are you talking about the liner?
March 10, 2010, 02:23:55 PM
dbiscayne
Re: new floor
« Reply #2 on: March 10, 2010, 02:23:55 PM »
how did you remove the original deck?
did you leave a small edge of original deck hanging out or cut it flush with the liner?
if you did leave an edge, are you going to put the new deck on top of that, or butt it flush to the edge?
just asking because if you are doing the former then yes the liner & edge need to be secured to something solid, the liner alone is pretty flimsy.  I'd glass it down to the outer stringer.  When I cut my deck out the liner was about an inch away from the side of the hull, not right against it.  Ended up cutting about 2 inches off the bottom of the liner so I can glass the deck to the hull side (plus my outer stringers are pretty screwed up & needed work), then glass the liner to the deck using a thin strip of foam sheet as backing for the new bottom 2 inches of liner.
March 10, 2010, 10:40:09 PM
aquasport
Re: new floor
« Reply #3 on: March 10, 2010, 10:40:09 PM »
i do have one inch left on the outer stringer. instead of cutting 2 inches off the panel, i grinded off 3 inches of gelcoat off, so when the new floor gets in i want to glass the floor to the panel, thank you for help
