Author Topic: Console deck or floor light.  (Read 661 times)
February 15, 2010, 10:33:44 AM
Read 661 times
Robob
« on: February 15, 2010, 10:33:44 AM »
One wire is pulled out of the port side light .
It has what looks like a white auto type plug. Is there a source for these?
Thank you in advance:-)
Bob on Tampa Bay
February 15, 2010, 12:08:20 PM
Re: Console deck or floor light.
« Reply #1 on: February 15, 2010, 12:08:20 PM »
Now we know what photo you want to post.
Are we talking the light or the connector?
Again, send me the pic and I'll post. You'll have your answer fast(er).
February 15, 2010, 03:00:34 PM
Robob
« Reply #2 on: February 15, 2010, 03:00:34 PM »
I discovered it is called a courtesy light.
Just the light would be okay with the two attached wires. I can put in some Ancor end connectors to splice the wires to the existing wires in the plug.
Do I have to create a Photobucket album to post the picture?
Bob on Tampa Bay
February 15, 2010, 04:16:52 PM
« Reply #3 on: February 15, 2010, 04:16:52 PM »
Quote from: "Robob"
On this Forum, yes.
Again, if it's a pic (or two) that will help you out, then send it to me.
I'll post it. :|
February 15, 2010, 08:28:37 PM
« Reply #4 on: February 15, 2010, 08:28:37 PM »
I'm guessing this is the light (bottom). Above is the LED version
Photo courtesy of Aswaff400... all rights reserved :wink:
Yes these lights are available at marine stores and on the net.
Google "boat courtesy lights' and go nuts. :idea:
Good luck
February 16, 2010, 10:02:24 AM
Robob
« Reply #5 on: February 16, 2010, 10:02:24 AM »
Mine is on a 1995 175 Osprey and is rectangular about 2 1/4 X 4 inches.
It has a white plastic bezel.
I Googled yesterday and could not find a rectangular light.
I'll work something out.
Thanks.,
Bob on Tampa Bay
February 16, 2010, 01:08:41 PM
« Reply #6 on: February 16, 2010, 01:08:41 PM »
Quote from: "Robob"
1995 175 Osprey
1995 200 Osprey
Now you must squint :wink:
The rectangular light is not visible in the 175 pic but is (look REALLY hard) in the 200.
When viewing the 95 catalog in real time, you can see the light with its white trim on the 200.
Now the quest begins in locating a replacement.
Unfortunately, this is as close as I could find in a hurry. Wrong color, funky movement.
http://www.basscatstore.com/courtesylight.aspx
Good Luck.
February 16, 2010, 05:10:47 PM
Robob
« Reply #7 on: February 16, 2010, 05:10:47 PM »
Thank you.
I may have to use different fixtures and replace the old ones with LED models:-)
Thanks again,
Bob on Tampa Bay
