Author Topic: installing sink in explorer  (Read 1421 times)
February 09, 2010, 10:59:45 PM
Read 1421 times
fishingdave
« on: February 09, 2010, 10:59:45 PM »
can some one post pics of where your , water tank is , fill, transom shower, and plumbing configuration of the sink. My boat doesn't have this luxury and i would love to install one in.
2005 aquasport 225 explorer
2005 Yamaha 200F
February 10, 2010, 03:17:42 AM
Double Trouble
  • NorthEast
Re: installing sink in explorer
« Reply #1 on: February 10, 2010, 03:17:42 AM »
What size Explorer and what year. That would help to figure out if you can do it.
February 10, 2010, 10:06:38 AM
fishingdave
« Reply #2 on: February 10, 2010, 10:06:38 AM »
2005 225 explorer
2005 Yamaha 200F
February 11, 2010, 09:04:49 PM
labboss2003
« Reply #3 on: February 11, 2010, 09:04:49 PM »
I have the same boat will take some pics and put them up
February 11, 2010, 10:28:01 PM
fishingdave
« Reply #4 on: February 11, 2010, 10:28:01 PM »
great thanks!
2005 Yamaha 200F
February 12, 2010, 09:54:28 AM
jcaesar625
  • FL - North Area
« Reply #5 on: February 12, 2010, 09:54:28 AM »
I'm actaually thinking about taken out my sink, and building a tackle center there. I never use the sink. The fresh water hose on the transom is all I need.
February 16, 2010, 05:15:10 AM
labboss2003
« Reply #6 on: February 16, 2010, 05:15:10 AM »
Took some pics but dont think they will help you.....as far as the plumbing goes the pump is on the right hand side trough the small doornext to bait tank ,down and towards the bow kinda hard to replace.Maybe sea bob could chime in to the wearabouts of the holding tank? Think it is under the step in the cabin?If thats where its at ,might be a tough job to retrofit .
February 16, 2010, 02:32:32 PM
« Reply #7 on: February 16, 2010, 02:32:32 PM »
Fishing Dave, Bob,
Now, I know this may sound terrible, but I stood next to a 1000 Explorer hulls being built, and never noticed where the FW tank was installed!  I can tell you on an Osprey, but that don't help... :thumbdown:
I'm really thinking it may be located in the port wing of the helm area by the passenger seat.  There is a large open area between the vertical face of the wing and the hullside.  If it is indeed under the companionway steps, well, then, I would shoot the assh0le who decided it should go there!
The pics Bob posted are exactly as they were installed back then, pump behind the small door portside of the livewell, transom shower in the transom walkthrough, blue water lines running forward...that get's me thinking, just a minute...
Bob, have you ever pulled that sink out?  Obviously removable with 6 screws.  Could that be where the water tank lives?  Maybe?  If so, then the retrofit would be a piece of cake...kind of!
February 16, 2010, 03:14:34 PM
labboss2003
« Reply #8 on: February 16, 2010, 03:14:34 PM »
Yes I have pulled the sink. Big hole its not under there.Good spot for a tackle draw.The filling spout is on the port  side, thats why I am thinking its under the step in cabin.
February 16, 2010, 03:21:42 PM
labboss2003
« Reply #9 on: February 16, 2010, 03:21:42 PM »
I will do some more snooping around since i cant use my boat anyway :pale:
February 16, 2010, 03:58:24 PM
labboss2003
« Reply #10 on: February 16, 2010, 03:58:24 PM »
sink
and behind door #1
ding ding where seabob said(and by the way he's the man)
So wouldn't be so much of a hard thing to do, probally harder to find the parts then do the job.
February 16, 2010, 04:29:27 PM
« Reply #11 on: February 16, 2010, 04:29:27 PM »
labboss (Bob),
AWESOME PICS!  Well done sir, YOU ARE THE MAN!
Good to see everything is still in pretty good shape behind the bulkhead/panel.  The black grime on your water tank vent hose is pretty typical in any water system.
By removing that b/head, a water tank can be slid in (awkward, but doable!) and secured.  As you look aft towards the rod rings, it is a pretty easy run with a snake back to the transom for a transom shower.  But, unlike Bob's boat, I would fab a small platform by he water tank and mount the FW pump in that area, then tee off the output side to feed the sink and the transom shower.
Back then we used Whale water line and fittings, and I still think they're the best.  Here's a link...Whale Water Systems.
You can get the stuff at WM, but you'll find it cheaper on the internet.
Thanks for the help, Bob! :thumleft:
February 16, 2010, 05:45:23 PM
fishingdave
« Reply #12 on: February 16, 2010, 05:45:23 PM »
thanks for all the pics , it looks great! not to hard to do. I notice there is a lot of wasted space under the sink. I might just do the transom shower , and save the sink area for tackle. What kind of custom work have you guys done for your tackle?
2005 Yamaha 200F
February 16, 2010, 07:40:09 PM
« Reply #13 on: February 16, 2010, 07:40:09 PM »
Quote from: "labboss2003"
I got a question :?:
What's that black hose in the upper left hand corner? :scratch:
February 16, 2010, 07:49:46 PM
labboss2003
« Reply #14 on: February 16, 2010, 07:49:46 PM »
The fill hose from the side of the boat
