Author Topic: Lower engine mounts  (Read 1753 times)
January 28, 2010, 07:33:21 PM
Read 1753 times
Lower engine mounts
« on: January 28, 2010, 07:33:21 PM »
The port side mount on my 97 200 rude has corroded thru the cover plate,anyone know
 whats involved in replacing the mount or both of them since i'm at it. :scratch:
January 28, 2010, 08:30:33 PM
Re: Lower engine mounts
« Reply #1 on: January 28, 2010, 08:30:33 PM »
Circle,
Are you talking about the mount where the motor bolts to the transom?
January 28, 2010, 08:48:33 PM
« Reply #2 on: January 28, 2010, 08:48:33 PM »
The mounts are just before the lower unit.I'll try to get a pic up.
January 28, 2010, 09:01:49 PM
« Reply #3 on: January 28, 2010, 09:01:49 PM »
Quote from: "Circle Hooked"
Wait a minute, I know what you're talking about...
I'll post a pic of a Yam...
Here we go.  Something like this?
January 28, 2010, 09:27:35 PM
« Reply #4 on: January 28, 2010, 09:27:35 PM »
Thats  it :thumleft:
January 28, 2010, 09:33:07 PM
« Reply #5 on: January 28, 2010, 09:33:07 PM »
January 28, 2010, 09:33:49 PM
« Reply #6 on: January 28, 2010, 09:33:49 PM »
Thats the cover plate
January 28, 2010, 09:39:03 PM
« Reply #7 on: January 28, 2010, 09:39:03 PM »
Circle,
You know, I might have hung the motor on your boat, but I'll say this.  I must have hung and rigged a 1000 OMCs (Ocean Runners/Ocean Pros) at in my time at AS, but I can honestly say I've never taken those covers off to see what they are hiding, and just what the bolts behind them do.
I mean, to pull the LU off to change a water pump, hell, you never go near them...so maybe I'll take the covers off the Yammi tomorrow and see what the deal is... :?
January 28, 2010, 09:50:12 PM
« Reply #8 on: January 28, 2010, 09:50:12 PM »
I'll get a pic of the motor in the morn and post it ,but behind the plate is what looks like a
lag bolt encased in a rubber bushing,the bushing is the size of the cover plate.
Thanks for taking your time to help Bob  i really appreciate it.
January 28, 2010, 09:59:52 PM
« Reply #9 on: January 28, 2010, 09:59:52 PM »
I'll see what's behind the cover plate on the Yammi...
Back in the the day in Sarasota, as you came into St. Armands from downtown, went halfway around the circle like you were going to Lido, there was a little restaurant calle "Tail O' the Pup"...served the best Hot Dogs you ever ate, and I'm from Chicago (Vienna Red Hots)...
Sometimes I actually miss Sarasota...go figure! :?
January 28, 2010, 10:04:01 PM
flkeysaqua
« Reply #10 on: January 28, 2010, 10:04:01 PM »
They are the mounts that hold the motor to the bracket that mount to your bolt they are on every motor and same as Bob I've looked at or dealt with them in my life either on any boat I've ever worked on.  Sounds like to me you had either a seal issue or an electrolysis issue for those plates to corrode like that.
73 19-6 w/140 Evinrude
January 28, 2010, 10:06:08 PM
« Reply #11 on: January 28, 2010, 10:06:08 PM »
Like the saying goes,you don't miss it till it's gone.
January 28, 2010, 10:08:00 PM
flkeysaqua
« Reply #12 on: January 28, 2010, 10:08:00 PM »
yup :D
January 28, 2010, 10:27:21 PM
« Reply #13 on: January 28, 2010, 10:27:21 PM »
Quote from: "flkeysaqua"
From what a found so far doing research it's not common.
And im sure it's not electrolysis
January 28, 2010, 10:57:17 PM
« Reply #14 on: January 28, 2010, 10:57:17 PM »
Now the fun part is finding new ones... :?
