Author Topic: osprey 250 repower  (Read 1079 times)
January 20, 2010, 06:39:30 AM
Read 1079 times
terry tessarzik
osprey 250 repower
« on: January 20, 2010, 06:39:30 AM »
I am considering replacing the  twin OMC Seadrive 140's on my '89 osprey 250. Any thoughts on repowering? 1 large single versus twins: E-tec vs Yamaha 4 strokes etc... I would appreciate any comments. thanks, Terry (new member, owner of a 20' AS striker as well)
January 20, 2010, 02:24:13 PM
resyak
Re: osprey 250 repower
« Reply #1 on: January 20, 2010, 02:24:13 PM »
Hi
I recently changed my old rude for a suzuki Df 225.
Here a post where I explain the reasons why I chose this motor.
The fuelconsumption is 3.8. mpg at cruisingspeed 27 m/h. When trolling its less than a gallon per hour ( 1000 rpm ).
Top speed is about 43 m/h.
viewtopic.php?t=5035
Advantage of twins: I one fails you have the other, so you never will have a problem to come home.
Disadvantage: More weight, more fuelconsumption and higher maintenance cost.
Hope my comments are helpful.
Regards
January 20, 2010, 02:55:23 PM
Mad Dog
« Reply #2 on: January 20, 2010, 02:55:23 PM »
Quote from: "terry tessarzik"
To maintain the balance of the hull your replacement options need to tip the scales at nearly the same weight as the I/O's.  First determine the weight of the equipment you are removing.  Second, determine how you want the outboard(s) installed; Porta-Bracket, Flotation bracket, or cut-out the transom.  If you choose a bracket, you will need the over-all weight of the the new power to be 60 to 120 pounds lighter to keep the boat balanced.  That may be hard to achieve with twin engines.  My 225 Suzuki weighs in at 460 lbs (as I recall).  Weight is major consideration and know the brackets exaggerate the affect.
MD  :wink:
January 20, 2010, 04:13:20 PM
resyak
« Reply #3 on: January 20, 2010, 04:13:20 PM »
Hi
The suzuki 225 weighs 580 lbs, the yamaha weighs 604 lbs, the Suzuki 300 604 lbs ( Yamaha 804 lbs ).
Regards
January 20, 2010, 04:27:33 PM
Mad Dog
« Reply #4 on: January 20, 2010, 04:27:33 PM »
Quote from: "resyak"
Hi
Regards
Is that the 2 or 4 stroke Suzuki @ 580?
MD  :wink:
January 20, 2010, 05:34:20 PM
buffalo bill
« Reply #5 on: January 20, 2010, 05:34:20 PM »
Hay, I'm Italian and my boat it's a 250 osprey... I don't now something abaut it, have You some photo or manual, weight ecc..?
Many thanks, Pier. :drunken:
Pier  La Spezia _ 250 OSPREY
January 20, 2010, 05:34:59 PM
« Reply #6 on: January 20, 2010, 05:34:59 PM »
Quote from: "Mad Dog"
MD  :wink:
OMC Seadrives
http://rides.webshots.com/photo/2253534740091848696LOEBGf
Look at the image at the top of the page at this link
http://www.google.com/imgres?imgurl=http://continuouswave.com/whaler/reference/images/omcSeaDrives387x342.jpeg&imgrefurl=http://continuouswave.com/whaler/reference/engineBrackets.html&h=342&w=387&sz=32&tbnid=Z7yMs3jZklwAiM:&tbnh=109&tbnw=123&prev=/images%3Fq%3DOMC%2BSeadrive&usg=__z4B3rErrLJurosK0iRNnQ2UPFDQ=&ei=cYRXS9_MG4eVtge249GsBA&sa=X&oi=image_result&resnum=5&ct=image&ved=0CBkQ9QEwBA
January 20, 2010, 05:41:34 PM
« Reply #7 on: January 20, 2010, 05:41:34 PM »
Welcome aboard Pier  :!:  :!:
Makes about 3 or 4 members now from Italy  :thumleft:
What year Osprey do you have?  Have any pics?  That's a big Osprey  8)
You and Terry can compare notes here.
January 20, 2010, 06:06:25 PM
resyak
« Reply #8 on: January 20, 2010, 06:06:25 PM »
Hi
It's the 4 stroke
Regards
January 20, 2010, 10:31:23 PM
Mad Dog
« Reply #9 on: January 20, 2010, 10:31:23 PM »
Quote from: "RickK"
OMC Seadrives
Okay, no more posting when I should be working.   :oops:
MD  :wink:
January 20, 2010, 11:46:25 PM
Asport-Rog
« Reply #10 on: January 20, 2010, 11:46:25 PM »
The E-Tec 250 weighs in at 518#  :thumleft:
1977 AS 170
Criticism is easier than craftsmanship
January 21, 2010, 02:30:52 PM
resyak
« Reply #11 on: January 21, 2010, 02:30:52 PM »
Hi
Your seadrives weigh around 300 lbs each.
So you won't have problems with a big single.
I think that 200,225,and 250 4 stroke weigh the same.
Etec's are lighter, but they are 2 strokes.
Regards
January 22, 2010, 01:48:25 PM
buffalo bill
« Reply #12 on: January 22, 2010, 01:48:25 PM »
Tanks Rick, thanks guys,
I think my osprey it's about 22 or 23 year old, it have the hull with the lower half bow in grey like models '85/'86 but it have a vee of about 19 degree like CCP, and next week I can test the weight without engine.
I have some photo but I dont know to put on this post... someone can help me?
January 22, 2010, 08:09:16 PM
« Reply #13 on: January 22, 2010, 08:09:16 PM »
Quote from: "buffalo bill"
E-mail them to me Bill,
I'll post them.
rb53@comcast.net
