Author Topic: Livewell leaning post options  (Read 949 times)
January 15, 2010, 10:49:44 AM
Read 949 times
kris Craft
« on: January 15, 2010, 10:49:44 AM »
I am looking for a livewell leaning post option.  I want a simple design like Hammerhead's but at less $$$.  Are there any other manufacturers of an oblong sit on top tank.
Kevin
January 18, 2010, 12:09:00 AM
Re: Livewell leaning post options
« Reply #1 on: January 18, 2010, 12:09:00 AM »
Kevin,
You could look for an oval poly tank to fit inside a glass outer box. Find a small rectangular fiberglass utility/dock box. Foam the oval tank in to the glass box for stability. You will prob need to raise the leaning post/backrest above the box on custom aluminum tubular posts. Daggone those T-Top shops.... :)
I have a similar built-in on my '95 Pursuit 2470 CC. Good arrangement, seat/backrest above an oval tank, but this unit was part of the liner, and not going anywhere.
Thing is, you want some confidence in your design/engineering.  Make sure what you end up with is overbuilt for the job, stable, part of the boat. That 40 gallons of water weighs around 300 lbs, and its up on the deck. Keep the plumbing internal (like the Hammerhead) so won't be tripping over that mess when the fishing gets to catching. And make sure you're outlet size(overflow)  is at least 2X as large as the intake; i.e., 3/4 in, 1 1/2 out, or more.
Safety note: Many boats have sunk due to poor livewell engineering/maintenance. MAKE SURE to have quality ball-cocks above thru-hull fittings, inlets AND outlets. Why outlets, that seems unnecessary, right? Almost sunk my 1979 2100CC Hydrasport 25 years ago, while offshore by myself. The 1 1/2 in outlet hose failed (split) , and the water continued to pump into the aft below-deck livewell. Noticed the boat got heavy; found the problem; shut off the pump, and the inlet seacock;  but no way to shut off the intrusion flowing by water pressure from BELOW(seawater)  in to the 1 1/2 inch outflow, due to the breach. Was lucky, got it up on plane, and ran the bilge pump home. Ran the boat straight to the ramp and trailer. Very lucky, very fortunate. And this was Hydra-Sport factory rigging, circa 1979.
Have checked the Hammerhead site, since I've been been hunting an old Aquasport for a while. Spoken with them, too. I don't think they're out of line for what they produce. And wow, I'm pretty impressed with their  stuff.
They advertise that livewell/seat for 800 bucks. Its a beauty, heavy acrylic lid, blue gelcoat interior, baffled, finished, all internal, hidden plumbing. My luck would be I'd try and duplicate it, and the whole mess would wash out in a heavy following sea.
You could whiz away 600 bucks trying to duplicate it, or go ahead and spend 200 more, and have something THEY are responsible for, or at least have onus to. Just a thought.
Best, keep us posted.
January 19, 2010, 07:44:20 PM
mikey gofast
« Reply #2 on: January 19, 2010, 07:44:20 PM »
There are a couple guys making very nice bait tanks in the Texoma (texas OK border Corp lake).  Check out a site sixoldgeezers.com and look around.  Both advertise there.  Very well built tanks with great filtration for the shad used on the lake.
January 20, 2010, 05:25:55 PM
kris Craft
« Reply #3 on: January 20, 2010, 05:25:55 PM »
Dont really want to build one myself as I have enough projects.
I will check out the texas/oki guys.
thanks,
kevin
