I need this hatch for my 2001 215 Osprey Sport, help!
Topic: I need this hatch for my 2001 215 Osprey Sport, help! (Read 1635 times)
January 04, 2010, 01:41:14 PM
Read 1635 times
camar0
January 04, 2010, 01:41:14 PM »
I have looked everywhere and i cannot find this
I think they call it an inspection hatch
I need a new one or even a non broken one
this was above water tank, infront of motor basically
Outside: Length ~15 ¾ Width 12 ¾
Inside: Length ~12 ½ Width ~9 ½
Picture of hatch:
January 04, 2010, 02:01:41 PM
Rigging Master
Re: I need this hatch for my 2001 215 Osprey Sport, help!
January 04, 2010, 02:01:41 PM »
camar0,
Unfortunately, all I see is a "picture icon". Sure you are uploading correctly? If I had a pic, I may be able to help...
January 04, 2010, 02:03:18 PM
camar0
January 04, 2010, 02:03:18 PM »
its not a upload because this site apparently does not like a jpg
direct link:
http://i980.photobucket.com/albums/ae28 ... /hatch.jpg
January 04, 2010, 02:21:20 PM
Rigging Master
January 04, 2010, 02:21:20 PM »
camar0,
I always use photobucket, just seems to work the best on all the forums...
Anyway, flip over the hatch and see if there is any manufacturers name molded in on the underside. Wellcraft/AS used to use a lot of Rabud Products back then so it may be one of theirs. If not, I'm sure we can find a suitable replacement. Check these guys out, we use them at Proline.
http://store.gotohmg.com/categories/Products/Innovative-Doors/
Sounds like an 11" X 15" might be the ticket...
January 04, 2010, 07:39:59 PM
Global Moderator
January 04, 2010, 07:39:59 PM »
This looks like it to me, well pretty close anyway
http://images.google.com/imgres?imgurl= ... 4%26um%3D1
Model # 39602
So-Pac brand.
Click on their link and find the above model number. It is a fairly close match to the dimensions you show.
January 04, 2010, 08:52:28 PM
Rigging Master
January 04, 2010, 08:52:28 PM »
Bob,
Bob
January 07, 2010, 07:44:47 AM
camar0
January 07, 2010, 07:44:47 AM »
thanks for the input
... i will check into this hatch
January 19, 2010, 07:58:47 AM
camar0
January 19, 2010, 07:58:47 AM »
This is the correct hatch, thanks... just got in mail
surprising i could only find from one seller on the west coast....
any recommendations for sealant when putting it back in?
January 19, 2010, 08:17:36 AM
Global Moderator
January 19, 2010, 08:17:36 AM »
Quote from: "camar0"
3M 4200
Edit:
You may want to also consider 3M 4000.
While the 4200 is a polyurethane compound the 4000 is polyether (I believe that's correct).
Difference?
Some plastics react to the urethane (think soften/dissolve) but seem to handle the ether.
I would check with your hatch manufacturer to see if they recommend any special sealant. Beckson (sp) calls for silicon only on their products (deck plates/hatches) so it can't hurt to check.
I'm planning on using the 4000UV on my new plates and hatches to be on the safe side.
Good Luck.
January 20, 2010, 11:46:04 AM
MikeR
Reply #9 on:
January 20, 2010, 11:46:04 AM »
I had the exact same problem with mine and couldn't find the exact size anywhere. Ended up getting on that was within 3/8 of an inch from GlenMar and it worked just fine. I put mine in with 5200...
December 16, 2010, 11:26:25 AM
Mulv80
Reply #10 on:
December 16, 2010, 11:26:25 AM »
Resurect this old thread, I need this hatch and havent had any luck finding one. Apparently, So-Pac has discontinued it. :cry:
99\' Aquasport 215 DC, Johnson 200 Ocean Pro
September 09, 2023, 02:17:05 PM
Scode68
Reply #11 on:
September 09, 2023, 02:17:05 PM »
I wish you guys would have posted makes and model numbers cause I need one of these hatches. The links posted are dead and I dont have an old hatch to look for info molded into it.
2001 Osprey 215 Sport
