Author Topic: 225 Explorer Faucet  (Read 972 times)
December 30, 2009, 08:21:55 PM
Read 972 times
bobterisch
225 Explorer Faucet
« on: December 30, 2009, 08:21:55 PM »
Happy Holidays Everyone,
The faucet in the cabin of my 2002 225 explorer is broken off. I want to relace it. When I removed the old one there were no wires attached to it and it appears that it never had any; but he sticker on the faucet says its a model 94-009-32 12VDC, 3amps max. Does this faucet require 12 volts or was it just used by turning on the fresh water pump and operating manually?
Thanks and Happy new year,
Bob
2002 225 Explorer
225HP 4 Stroke
December 30, 2009, 09:54:20 PM
Re: 225 Explorer Faucet
« Reply #1 on: December 30, 2009, 09:54:20 PM »
there is pressure switch on the pump that goes on and off as you use water,no wires at the faucet
December 30, 2009, 09:59:34 PM
« Reply #2 on: December 30, 2009, 09:59:34 PM »
Bob,
My guess as to your faucet (hey, I left in '00, but it still would be an "educated guess"!!) is that that when you turned on your old faucet, it in turn turned on the pump.  Is there a "Fresh Water" switch at the helm switch panel?  If not, I'd say this was the deal, hence the voltage/amp callouts. The fresh water pump may have also been energized by an Accessory switch at the helm.  Give all the "ACC" switches at the helm a try and see if any turn on the pump.
If the faucet did indeed turn on the pump, than there has to be, or have been, some wiring somewhere nearby.  Pull any access plates or storage compartments in the sink area and poke around.  Let us know the outcome...
Bob C
December 31, 2009, 04:23:44 PM
« Reply #3 on: December 31, 2009, 04:23:44 PM »
You could also have a manual faucet - with the pump on the faucet:
http://www.westmarine.com/1/1/10285-roc ... spray.html
Actually, it usually costs less to do a 12 volt pump with an inexpensive faucet:
http://cgi.ebay.com/ebaymotors/JABSCO-B ... iesQ5fGear
Hope this helps - see ya on the water!
January 01, 2010, 02:13:23 PM
bobterisch
« Reply #4 on: January 01, 2010, 02:13:23 PM »
Happy new Year everyone,
Thank for all your replies. As Pete & Bob wrote the pump is powered by the accessory switch. Bob that is the faucet in the picture except mine does not have the 2 wires.
Thanks all,
Bob
2002 225 Explorer
225HP 4 Stroke
January 01, 2010, 03:16:20 PM
« Reply #5 on: January 01, 2010, 03:16:20 PM »
Bob,
Probably what the issue is that Shur-Flo sold the same faucet as the one you have in both the internally switched model and the model that uses a separate switch to turn on the pump, which would be yours.
If you wait a couple of weeks, I can get you either the "Deck Tap" for $30 or the "Folding Tap" for $25.  They both should cover the existing hole you have on top of your galley counter.
Bob C
January 01, 2010, 03:20:49 PM
« Reply #6 on: January 01, 2010, 03:20:49 PM »
So you have to go out and turn the switch on at your dash to go back down to use your faucet. Why didn't they put the switch next to the faucet :scratch:
Does the pump service other things too? Like fresh water washdown, etc?
January 01, 2010, 04:35:50 PM
bobterisch
« Reply #7 on: January 01, 2010, 04:35:50 PM »
Yes there is a fresh water shower in the transom. It was cold here in NY when i got the boat so I have not had a chance to put water in the system and try it.
2002 225 Explorer
225HP 4 Stroke
