Author Topic: New LI owner of a 2001 AS 225 explorer Question for SEABOB!!  (Read 2046 times)
November 28, 2009, 12:06:50 PM
jdevoid
Re: New LI owner of a 2001 AS 225 explorer Question for SEABOB!!
« Reply #15 on: November 28, 2009, 12:06:50 PM »
Seabob, or Rickk
Your advice is well taken. The boat leans to starboard even with the outboard turned and tilted up to port. I got the boat in Sept- and never loaded it up with gear. I did set up the boat and stored my limited gear on port side cabin and cockpit- and still no difference. The ass end is out odf the water- very bow heavy. I found no water in the bolgs or transom area either.
I wonder if this is simply normal, as you've suggested, and  should just go with the 150lbs of ballast.  BTW- if you look at my pics you'll the disparity in water level when looking at the water line.
November 29, 2009, 04:36:43 AM
labboss2003
« Reply #16 on: November 29, 2009, 04:36:43 AM »
On my 98 225 exp I have three batteries in the back .I removed the oil tank and mix the gas and oil in main tank I then reran the wash down pipe to where the oil fill was. This was done because I dont want to run out of oil because of a brain fart. As far as the third battery goes I run my stero bait pumps underwater light and deck lights off of it ,do not want to run the chance of not having a good battery when 40-70 miles offshore.
Never noticed if the boat was leaning one way or the other, but I am close to 300lbs so when I get on any boat it tends to lean:)
November 29, 2009, 09:27:56 AM
« Reply #17 on: November 29, 2009, 09:27:56 AM »
Quote from: "jdevoid"
The ass end is out of the water- very bow heavy. I found no water in the bolgs or transom area either.
The Explorers are bow heavy - I guess the helm area/cabin roof is pretty heavy.  I don't see an alarming amount of tilt in the pics and if it doesn't run weird, just ignore it and enjoy the boat instead.  :D
November 30, 2009, 11:56:49 PM
stringali
« Reply #18 on: November 30, 2009, 11:56:49 PM »
Hey Randy and Waterman, We should start a little annual Aquasport of Long Island get together this Summer, like the boys in Florida do!
Steve  :santa:  :rendeer:
PS. My baby is all winterized, how many months till spring?
December 01, 2009, 09:30:02 PM
waterman
« Reply #19 on: December 01, 2009, 09:30:02 PM »
Sounds good.........5 months till spring
December 04, 2009, 07:19:55 PM
stringali
« Reply #20 on: December 04, 2009, 07:19:55 PM »
Hey, March 15th i am thinking fishing!  Have a great Holiday Season.
Steve :santa:
my email is string0716@verizon.net
December 06, 2009, 10:13:32 AM
jdevoid
« Reply #21 on: December 06, 2009, 10:13:32 AM »
Yes, I cannot wait until spring. Just purchased a Shimano Tekota 500- Soujourn rod and a Shimano Calcutta 400b with a Saragosa rod. I'm a novice/noobie to fishing but I should be looking the part at least. I cant wait until the guy in his 1962 19ft CC laughs at me trying to fish while pulling up the big fish.
December 08, 2009, 05:59:18 PM
aquasport79
« Reply #22 on: December 08, 2009, 05:59:18 PM »
I guess your boat does not have Bennett Trim Tabs....
They will fix any kind of ride problem  & make your boat run perfectly
in any type of weighting conditions.
Your boat runs a bit different all the time:For Example,
# of People on board
Amount of gear on board
Heading out into the Ocean swell with full Fuel tanks
Coming In with the swell and empty fuel tanks
Just install a good trim system!
December 08, 2009, 09:46:28 PM
jdevoid
« Reply #23 on: December 08, 2009, 09:46:28 PM »
I have Bennett trim tabs. My concern is basically while just floating in the calm water-the boat has a noticable lean to starboard. Rickk and Seabob also explained how under way the trim tabs will help. Again- I am just surprised the boat, without any gear, leans.
