Author Topic: 1973 Aquasport 19-6 Rebuild  (Read 43767 times)
August 08, 2010, 11:09:33 PM
Reply #195
thennutts
Re: 1973 Aquasport 19-6 Rebuild
« Reply #195 on: August 08, 2010, 11:09:33 PM »
Quote from: "RickK"
Looking good  :thumleft:
If you can do it I would plan the batteries inside the console.  You will have enough weight in the aft with the lever effect of the porta and motor 12" back or more.
My $.02
Rickk,
Only 1 battery will be going into the back part, this will be the starting battery and what runs the power pole hydraulic and porta lift hydraulic, the other 5 batteries will be under the center console( 3 batts 36v trolling motor and 2 for electronics).
August 09, 2010, 05:27:12 AM
Reply #196
« Reply #196 on: August 09, 2010, 05:27:12 AM »
Man that's a lot of batteries  :shock:  Hate to be on the paying end of that every 3 or 4 years to replace them :cry:
August 09, 2010, 06:52:51 PM
Reply #197
thennutts
« Reply #197 on: August 09, 2010, 06:52:51 PM »
Quote from: "RickK"
Yeah, I hear ya. It's a big initial bill, but I am able to switch out all my optima batteries no matter what the time frame if they fail, my last ones lasted 6 years no problem and got replacements free. Nice to have someone in the family who deals them!
October 24, 2010, 04:59:17 PM
Reply #198
thennutts
« Reply #198 on: October 24, 2010, 04:59:17 PM »
Bottom Painted Jet Black
Sonar, depth, Temp Brass Thru Hull
High Speed Pick Up Brass Thru Hull
2nd Station Painted Black
Fuel Line Ran
Full Transom Arch Built
Top side of thru hulls
October 24, 2010, 06:38:44 PM
Reply #199
« Reply #199 on: October 24, 2010, 06:38:44 PM »
That's some deep gloss :thumright:
October 24, 2010, 07:36:11 PM
Reply #200
Mike453
  • NorthEast
« Reply #200 on: October 24, 2010, 07:36:11 PM »
Wow! I've been slacking keeping up on your progress, unbelievable job. The workmanship looks great,and you say you never used fiberglass before,I know guys been in the business 30 + and can't hold a candle to your work! I went back and read all 14 pages just to refresh , my memory,(what little is left), Again what a great job, keep up the good work. looking forward to seeing more.Mike :thumleft:
2000 aquasport 200 osprey with 115 johnson
October 24, 2010, 10:15:23 PM
Reply #201
« Reply #201 on: October 24, 2010, 10:15:23 PM »
Been very impressed from start 'till now. Heckuva layup, and real sweet work.  Keep it up.....hang that 140 Suzi that Jesse is running.... you're through!
 :cheers:
October 25, 2010, 02:45:30 PM
Reply #202
thennutts
« Reply #202 on: October 25, 2010, 02:45:30 PM »
rickk-  thank you, would you believe that this paint was rolled on and not sprayed? its true
Mike- i appriciate the complements, means a lot. guess those "how to" fiberglass dvd's i bought worked out well haha
Gran- 140hp would be nice, but there is a beautiful yami vmax 225 ox66 sitting in my garage, sure would be a waste not to use it :)
October 25, 2010, 08:25:27 PM
Reply #203
« Reply #203 on: October 25, 2010, 08:25:27 PM »
Heck yea, if you already have it....slap her on there!
November 04, 2010, 07:15:38 PM
Reply #204
blindmullet
« Reply #204 on: November 04, 2010, 07:15:38 PM »
You might want a chase tube for the fuel line.  If it needs replacing how can you do it once the deck is on?
November 04, 2010, 08:25:22 PM
Reply #205
bumpster
    • http://www.xtremeled.com
« Reply #205 on: November 04, 2010, 08:25:22 PM »
Quote from: "thennutts"
Now youre talking.
December 08, 2010, 01:31:50 PM
Reply #206
Jon
« Reply #206 on: December 08, 2010, 01:31:50 PM »
Gents, Ive been hovering around this site for quite a while and posting drove me to register. I own your boats second cousin, a 20' Proline flatback. It came from Fort Myers and your story is very peculiar to me. I found the boat with a 150 vmax just over 70 hours, t top (wish I had money to burn on a minitower) powerpole. The gentleman I bought it from was a really good guy that knows alot about many things besides boats. He had it completely redone which is where this story goes weird. Had it painted beautifully, new deck, new center console, non-skid matches the smurf blue hull, but there are several soft spots in the floor and they are more due to no being corretly tied into the stringers and bulkheads, than wetspots. I can see 1x 4s between the deck and stringers.  The deck forward of thecenter console dips when you step on it from a lack of support. It has me wondering if this work was done from the same shop you originally took yours to. Fortunatley, and hopefully, what I paid for the boat should leave room for most of the redo.
On a high note, what you have done looks very clean and when mine hits the shop for rebuild number two ( sounds a common theme on this site) I hope to stop in and see this kind of clean thought out work. Also I agree with the Hammerhead comments. I spoke with the gents there, very good guy, and I hope I can swing having them do the work, but their experience comes with a hefty yet honest pricetag. I simply dont have time.  Also, I agreed with someones earlier comments about checking better business, etc. I might add checking the sheriffs website. There is a certain shop in the Tampa area that has a gent with a long history of issues reflected in his business practices... doin my best to be Politically Correct here.
Thanks for the great information shared on this site.
December 08, 2010, 07:04:42 PM
Reply #207
« Reply #207 on: December 08, 2010, 07:04:42 PM »
Welcome aboard Jon  :!:  :!:
January 23, 2011, 06:17:51 PM
Reply #208
thennutts
« Reply #208 on: January 23, 2011, 06:17:51 PM »
Been trying to get back on this boat, with school full time and work full time its hard to try to fit this thing in, but I have made some progress since last picture posts!
Finished up the sides with the black
Measuring the Porta Bracket to make sure there will be no binding, I then made a template to place on transom to mark out
Mounted the Porta
Installed the Troll n Tab Minn Kota system
Installed 8' power pole pro stealth
Installed the Shodow-Caster 10v2 42 watt LED underwater light system
1/8" Aluminum plate on the inside for the Porta to relieve stress on wood transom
Power pole aluminum plate
New tow Eye in front of boat
Started painting the Bilge areas
January 23, 2011, 06:27:57 PM
Reply #209
thennutts
« Reply #209 on: January 23, 2011, 06:27:57 PM »
Made some good progress. Next step will be to put the boat back on the trailer and mount motor. Then i'm going to fill the boat with fuel, put the floor in the boat not fiberglassed, strap the tower down to the boat with ratchet straps, and float the boat to see how it sits. This will help me determine where everything so go and also allow  me to see where I should position the batteries, etc. Im thinking I may have to put the batteries in the front of the boat since there is so much weight in the back and since I eliminated the front step up? We shall see when I float her!
