Quote from: "bumpster"Take all that crap out and get yourself some foam filled stringers and laminate them in place. it will save on weight and it will be stronger in the long run oops. I think i came in way to late on this thread. My BADBumpster,Thanks for your thoughts but I would like you to put some reasoning behind your statements. This "crap" that you think I should scrap is $180 a sheet, used in mega yatchs, airplanes, submarines and plenty of other configurations where weight is key. There is a boat company by the name of "contender", maybe you have heard of them? They use this same exact foam but 3lb density( the stuff I have is 10 lb density, its 3 times the compression strength of 3 lb) in their boats with 1 layer of 1 1/2 mat and 2 layers of 1708 with plenty of bulkheads and that is how they make their stringer/bulkhead configurations in which they hang huge motors off of and deal with plenty of stress and flex. I amgoing to use1 1/2 mat, then 3 layers of 1708 and put as many bulkheads as can fit. Also, you bring up that it will save weight. I carried 4 of these 4 x 8 sheets across the warehouse I bought them from and loaded them myself into a truck, they dont weigh anything. I'd compare 1 sheet weight to a sheet of NON PT 1/4" plywood, hardly anything. Once I lay all the fiberglass and run my PVC tubes for rigging I will be using a very dense pour foam, it is a major structural pour foam, its 12 lb(most people use 4 lb). When cured its as hard as concrete. Even if you hit it full blow with a hammer, it will barely put a dent in the foam. When you combine all this, strength is not an issue. As far as your weight concern, there is no concern because it is so lightweight. I don't know, maybe we arn't on the same page or you are thinking of another product? But hey, if it is strong enough for contender boats it will be just fine in my little 20 aquasport. Especially with the way im doing it, im overdoing it if anything!!!-Chris
that cap should hold its shape fine if you wedge it up where its got the original sheer in it. i ran a strin g from bow to stern on the boat, took some sheer to string height measurements and set the cap up pretty close to those measurements. i assume you braced it upwhile it was still on the boat? should be golden if you did. only problem i had was in the back where the cap tried to spread a little, id span something across there to keep the width if i did it again. this is much better than glassing on your back haha
You'd never know it was the same boat as the one on page 1.Good job
