Author Topic: 1975 19-6 aka Time Capsule w/pics  (Read 3520 times)
November 06, 2009, 07:39:49 AM
Re: 1975 19-6 aka Time Capsule w/pics
« Reply #15 on: November 06, 2009, 07:39:49 AM »
The vents on my hull are chrome. Skoot says his are white plastic. Badonq's says his are white plastic also. So which are original, chrome or plastic? You can still get the plastic ones at West. Mine are extremely corroded, not sure if I'm going to replace them or not. Facing the way they do seems like they will catch a lot of spray and with no bilge pump yet would dump water in and not get drained overboarduntil you pull the plug.
November 09, 2009, 08:48:04 AM
Skoot
« Reply #16 on: November 09, 2009, 08:48:04 AM »
I took her out this weekend and the wind was howwwwling (Gusty NE-20-25mph)  The intercoastal had about 1' chop and she cut right through it, rode like a dream. (my last boat was a Carolina Skiff)  I ran the boat for about 3hrs, both idling and cruising speed.  She ran great, but I had to dump the brand new fuel/water filter twice in the 3hrs. The first dump, the gas was milky, second dump didn't look too bad.  Obviously theirs some gunk in the fuel tank.  Im about 99% sure my first major project is going to be replacing the fuel tank and all the fill/fuel lines.  Even with the fuel problems it was an awesome first trip.
1975 19-6 - 90hp Tohatsu
November 09, 2009, 10:06:45 AM
« Reply #17 on: November 09, 2009, 10:06:45 AM »
What, no pics!!!! :(
November 09, 2009, 05:10:26 PM
Marcq
« Reply #18 on: November 09, 2009, 05:10:26 PM »
No pictures!! BOOOOOOOOO :thumbdown:
;) Marc..
November 10, 2009, 09:22:52 PM
Skoot
« Reply #19 on: November 10, 2009, 09:22:52 PM »
Okay, got a couple pics, More to come soon.
November 10, 2009, 09:30:31 PM
Marcq
« Reply #20 on: November 10, 2009, 09:30:31 PM »
Looking good dude  :cheers:
Marc..
November 12, 2009, 10:57:55 AM
jdupree
« Reply #21 on: November 12, 2009, 10:57:55 AM »
Nice find!!!  Love the "original" plastic steering wheel with aquasport cap.
John L. Dupree, III
AQABLA84E999
Member #257
November 13, 2009, 10:10:32 PM
Anonymous
« Reply #22 on: November 13, 2009, 10:10:32 PM »
I am glad that you like the boat and would like to share a couple of thoughts with
you.  In the nine years that I had her, I never had a problem with water in the hull.
The scoops are original and are in the right direction.  You will not have a problem
with spray, but if you take a wave over the bow you could have a problem.  I thought
about a bilge pump, but then you run into wireing and discharge hose outlets.  I also
considered the results of a fuel leak and a possible spark from a wire joint or the pump.
Not a good result.  If you want to cut a hole in a good boat deck, consider a pump that
you can install when needed.  Put gator clamps on wire ends and a good discharge hose.
I believe that the gas situation will improve with more fresh fuel.
 I hope you will enjoy the boat as much as I did.
November 13, 2009, 10:21:59 PM
« Reply #23 on: November 13, 2009, 10:21:59 PM »
Quote from: "Skoot"
Can't you tell he is!
I'm just glad it worked out for both of you!
November 18, 2009, 01:29:55 AM
« Reply #24 on: November 18, 2009, 01:29:55 AM »
Scott,
Hi, would appreciate your advice/guidance per this same endeavor. Thanks!
Cannot access your profile, could you please send a quick mail to:
gran398@yahoo.com
Thanks Scott,
Regards,
November 18, 2009, 12:52:42 PM
Skoot
« Reply #25 on: November 18, 2009, 12:52:42 PM »
Patience, help from this site, more patience and more help from this site.
