Quote from: "Glock Diver"Capt. Bob- Thanks for sharing! Now if we could just get a moderator to create an Aquasport 225 section in the Photo Gallery, you'd have a place to post that brochure!I could only make out some of the fine print/specs on the left side... any chance you could zoom in on that text?GD,I'm pulling out the flatbed scanner I have and will be creating both jpegs and .pdf files of the four catalogs I picked up. Hang tight for a little longer (I'll do the 97 cat first) and I'll burn you a cd. You can then view it on your box with what ever photo editor you have. When I scanned what you see on the Forum, it's compressed so that I can get it to photobucket and then it's reduced again to meet Forum restrictions. Looks bad I know but when viewed with the computer at work, it reads just fine so.....Hang on, it's coming. I think you'll enjoy reading what was out there in 97.Currently, the Admins can't (and neither can we members) post to the Photo Gallery. This is a software problem the Forum has been dealing with for some time. Rick wants to post any and all Aquasport related data we can come up with and I just got lucky getting these. So give me a little time and I'll contact you so I can get you this info. PS.... For anyone else with a "Gen II" Aqua, I currently have a 95, 97 2004 & 2005 catalog/calendar. If interested, give me a PM.
GD,The first pic is a ground block. The heavy gauge black wire in the lower left terminal is coming from the battery (or there about). You might want to clean that whole strip up just a little. I do not see the positive (hot) terminal strip in the other pic. Do you have something along the lines of the first pic but with fuses attached?
Anyway, as far as your helm goes, well, at least all the wires going to your ground buss are black! I've seen worse. To wire your GPS power, run the ground to that same buss, and pick an accessory switch that's not powering anything, and wire your + to the middle position. That way you can turn on your GPS with a switch, and there is no need for an inline fuse as it is breaker protected. Just make sure the breaker size is appropriate for what the manual calls out for.For a fee, I'll be happy to run down and rewire your helm to MY specs...
Spent some more time under the helm today, cleaning mostly, but organizing some wires too. Capt. Bob- No, I definitely don't have a positive terminal strip. Looks like all the hot wires are coming from the back of my switch plate. Question: Should I add a positive terminal strip? Seems I've run out of free connections. I noticed today that both the Fishfinder and the AM/FM Stereo are getting their juice from the last fuse, and are spliced together. Since I'm looking to add GPS power also, is it OK to add to this? or should I install a new strip for things like this?So nobody can post to the photo gallery, eh? Strange! Hopefully they get it fixed and we can start an Aquasport 225 section!
