Author Topic: New project 1973 19'6  (Read 7796 times)
October 15, 2009, 01:59:05 AM
MarshMarlowe196
Re: New project 1973 19'6
« Reply #15 on: October 15, 2009, 01:59:05 AM »
Quote from: "terntwo 24"
Badonquasport196 you think the tanks that big that would be great, I stuck a 6' bar in there the tank moved but not a whole lot. just the front half is foamed in .The tank will have to wait until we get rid of these couple of Nor'Easters that are going to hit us this weekend ya know street flooding.beach erosion, and maybe some good surf fishing for the striped ones :cheers:
This is a pic I pulled from the photo gallery; it states the tank is 50 gallons
http://www.classicaquasport.com/gallery ... c1970s.jpg
The foam around that tank really holds on tight.  I'm sure with enough persuasion you can get it out with some pry tools, but the lift-truck sure made it feel like I was cheating.
Side note- your 240 is beautiful  :thumleft:
Key West 1720 / Yam C90
Sold: 1973 Aquasport 19-6
October 17, 2009, 08:53:52 PM
terntwo 24
« Reply #16 on: October 17, 2009, 08:53:52 PM »
Rick when it's time for non-skid I'll be using your method, I've used it on the 240 on the two deck hatches and the two boxes on the stern. White water runs and cream nonskid, just using perfection 2-part and mason sand sifted to the size I want for traction , not so coarse on the deck (barefeet) but a little coarser on the back part of the stern when stepping from the dock on to the boat (November & December mornings can put a little frost on them). At some point in time I'll do the whole deck and casting platform and gunnels. And I'll be doing the same nonskid method and colors on the 19'6. I have had a bunch of compliments on it. And I have to Thank You and everybody here.such a wealth of knowledge. Not much done on the 19'6 with back to back nor 'easters, alot of overtime setting barrels out for flooding here on the island.
76 24\' inboard cc
73 19\'6 cc
96 17\' carolina skiff
October 22, 2009, 10:03:21 PM
AquaSportNewbee
« Reply #17 on: October 22, 2009, 10:03:21 PM »
Great boat. i recently purchased a 1974 19'6 Aquasport for $500
I am still trying to figure out how to post my pictures.
October 23, 2009, 05:12:47 AM
« Reply #18 on: October 23, 2009, 05:12:47 AM »
Welcome aboard AquaSportNewbee  :!:  :!:
To post pictures you'll need to open an account with a photo hosting site - this example uses a free account from PhotoBucket.com.  Once you've opened an acct there, follow the instructions here.  Some of the screens have changed but the main points are still vailid.  Then start a new topic and show us your new family addition.
October 24, 2009, 09:30:52 PM
terntwo 24
« Reply #19 on: October 24, 2009, 09:30:52 PM »
Well I spent the morning working on the 240 battery issues(lack of use)Got that taken care of and jumped on the 19'6 to see if I could get the tank removed, after an hour of working on it she popped out.
Sme pitting on the bottom of tank
This is weird there is a small saw cerf that water was leaking from when I step near it
This was what the tank was sitting on resin on top bare on the bottom
76 24\' inboard cc
73 19\'6 cc
November 07, 2009, 07:41:25 PM
terntwo 24
Re: New project 1973 19'6 (Upadated 11/7/09)
« Reply #20 on: November 07, 2009, 07:41:25 PM »
Well I got some time on the boat today removed the back deck and found why water was leaking from the saw cerf, the balsa core was soaking wet and the glass was coming lose
This is the wood along the center stringer
How do you support the deck,cut the top deck and wood and leave the bootom flange
The stringers look in good shape but the glass on the bottom is coming lose, just put some resin and reglass?
These four holes were in the stringer,why?
Heres just the back deck again soaking wet.
I didn't want to get to crazy until I asked some question about how to support the new decking around the gunwales and the rear scupper area,
Any comments,suggestions,tips,are all appreciated,not sure how to reglass the deck and have support on the edges. Thank in advance Doug
76 24\' inboard cc
73 19\'6 cc
November 08, 2009, 08:23:02 AM
terntwo 24
« Reply #21 on: November 08, 2009, 08:23:02 AM »
Here are a couple more shots of what I found
76 24\' inboard cc
73 19\'6 cc
November 09, 2009, 09:08:04 AM
Skoot
« Reply #22 on: November 09, 2009, 09:08:04 AM »
It appears from the pics that only the top side of the deck is glassed.  Is that the case?  I thought that both sides were glassed.
Im curious myself.  I looked at a 1972 19-6 that had those same square cut outs in the stringers.  Maybe they act as vents to let any water evaporate that might get trapped in the foam stringers.
1975 19-6 - 90hp Tohatsu
November 09, 2009, 05:40:06 PM
terntwo 24
« Reply #23 on: November 09, 2009, 05:40:06 PM »
Hey Skoot, No the deck was glassed on both sides,some areas are real thick woven roven and some areas aren't as thick,The other stringers have the same size holes,but I think that was to pour the foam into the stringers, Could you answer my question about how to put the new deck down and support the deck along the sides?, not sure how close to cut the old deck to the sides.
76 24\' inboard cc
73 19\'6 cc
November 09, 2009, 06:04:07 PM
« Reply #24 on: November 09, 2009, 06:04:07 PM »
Most rebuilds look like they have left about 1 to 2 inches around the edge to bond to. Here is a link to shine's flatback rebuild on their site. Also maddog's is on that site also.
http://forums.bateau2.com/viewtopic.php?f=10&t=11294
This is maddog's
http://forums.bateau2.com/viewtopic.php?f=10&t=14052
Of course you can always look at lilrich's or lovetoflycessna's on this site.
November 09, 2009, 06:22:40 PM
terntwo 24
« Reply #25 on: November 09, 2009, 06:22:40 PM »
Thank You slvrlng, That helps me out, I have to go thru and read it more closely. I just have to go the photo gallery for lilrich's or lovetoflycessna's project?.
76 24\' inboard cc
73 19\'6 cc
November 09, 2009, 07:53:50 PM
« Reply #26 on: November 09, 2009, 07:53:50 PM »
Here's a start. http://www.classicaquasport.com/phpbb3/viewtopic.php?f=2&t=3802
November 09, 2009, 08:06:48 PM
« Reply #27 on: November 09, 2009, 08:06:48 PM »
Thanks Bob! I was looking for lilrich's and just now found it. Hey terntwo if anybody gives you any members name go to members list and search for their name by entering the first letter. Then you can go through their posts, lilrich's main thread is kind of obvious when you do this. I looked and here's his! Wow rick 30 pages!!!
viewtopic.php?t=957
Oh yeah what is your HIN and I'll add it to the 19-6 registry!
November 09, 2009, 08:58:17 PM
terntwo 24
« Reply #28 on: November 09, 2009, 08:58:17 PM »
Thanks guys I'll look over these post and I'll try to get the HIN#,but someone did a transom repair and some of the numbers/letters are covered up with glass,really appreciate the help locating the posts. Don't have much time right now we're trying to finish up paving projects before the weather goes south, and I do also(for few days)again Thank You slvrlng and Capt Bob.
76 24\' inboard cc
73 19\'6 cc
November 09, 2009, 09:08:28 PM
« Reply #29 on: November 09, 2009, 09:08:28 PM »
Quote from: "slvrlng"
Bingo  :thumright:
