Author Topic: 2002 Mercury 2.5L 200hp Poppet Valve  (Read 819 times)
September 29, 2009, 11:05:08 AM
Read 819 times
CThomps
« on: September 29, 2009, 11:05:08 AM »
It's an offshore series motor.  Not sure if that matters.
Does anyone know the part number?
I've discovered something about engine parts online.  They're friggin cheap(er).  Local Merc dealer wanted $314 plus tax for a Mercury control box.  The internets found it for me for $242 delivered.  Installed it yesterday and what a difference a new control box and cables makes!  Idled like a champ and throttle forward very gracefully.
Thanks in advance.
September 30, 2009, 10:52:50 PM
bdtsr
Re: 2002 Mercury 2.5L 200hp Poppet Valve
« Reply #1 on: September 30, 2009, 10:52:50 PM »
Go to Mercury parts express, there should be diagrams and numbers for your motor. If you have not done so, do the thermostats and water pump as well. Just make sure you get the little rubber seal that goes on the thermostats. Be carefull of the top bolt on the poppet valve cover, they can be rather tight (corrosion wise).
1978 Aquasport 200 CCP 1990 225hp Yamaha
1990 Bayliner 2302 Trophy 2000 225hp Optimax
1999 Bayliner 1950 Capri Bowrider Merc 3.0 liter I/O
1986 Arrowglass CC w/1986 Evinrude 115hp
3 Kawasaki Tandem Sport Jet skis
1993 Seadoo XP
1988 Yamaha WR500
