Author Topic: 222 CCP Rebuild  (Read 10258 times)
November 04, 2009, 06:37:21 PM
Marcq
Re: 222 CCP Rebuild
« Reply #15 on: November 04, 2009, 06:37:21 PM »
Looking good man!! How's the console doing?
Marc..
November 05, 2009, 11:53:49 AM
Keith Knecht
Re: 222 CCP Rebuild
« Reply #16 on: November 05, 2009, 11:53:49 AM »
Still in the grinding stage.
November 25, 2009, 11:25:50 AM
Mark Sr
Re: 222 CCP Rebuild
« Reply #17 on: November 25, 2009, 11:25:50 AM »
Have you decided or done anything else to the splash well.I'm looking at one but the splash well area has got me undecided.
Mark Sr
Mark Sr
January 21, 2010, 03:14:32 PM
Keith Knecht
Re: 222 CCP Rebuild
« Reply #18 on: January 21, 2010, 03:14:32 PM »
It's been awhile. Haven't gotten much done.  Cut out the plywood that someone had installed under where the coffin would be.  No wood here, RIGHT!  It was solid, I'll give them that.  It wouldn't have been so bad but they didn't glass any of the wood that they put in.
July 13, 2010, 01:13:25 PM
Keith Knecht
Re: 222 CCP Rebuild
« Reply #19 on: July 13, 2010, 01:13:25 PM »
Here's a few more pics with the cap and inside gunnels painted.
July 18, 2010, 01:12:38 PM
saltfly
Re: 222 CCP Rebuild
« Reply #20 on: July 18, 2010, 01:12:38 PM »
Hey keith how thick is your deck? The total thickness. It looks alot thinner in the pic's, then what my 81 is. My 81 looks to be 3/4 of a inch thick. At least in the front, were the two hatch covers are.
August 06, 2010, 09:40:54 PM
222 ccp dgraf
Re: 222 CCP Rebuild
« Reply #21 on: August 06, 2010, 09:40:54 PM »
My rebuild is a 1988 222 ccp and my plywood in my deck is a 1/2 inch with a heavy layer of glass top and bottom. The quality of the glass work on my boat is bad so I am laying up the entire inside bottom and inside the stringers with two layers of 1708 (on top of one layer of 1-1/2 oz mat) Can you say LOTS OF RESIN!!! This project has no end and for what boats are going for here I would have been able to buy two for what I will have in this one. Good to see some 222 ccp's on here wish there were more.
August 08, 2010, 09:14:26 AM
Re: 222 CCP Rebuild
« Reply #22 on: August 08, 2010, 09:14:26 AM »
Decks on CCPs from late 70s through about 1990 were 1/2" marine ply with glass overlay on the top and bottom.  The decks sit on the stringers, with the center open and the outboard areas foamed.  A storage bin was installed in front of the coffin area, but - and this is pretty interesting - some boats did not have a hatch installed to give access to the forward storage bin.   :scratch:  I've seen some CCPs without the hatch, but when you look under the deck (through the deck plate under the coffin), you see the storage bin has been molded in - weird, huh?   :roll:
See ya on the water!
August 22, 2010, 08:13:42 PM
saltfly
Re: 222 CCP Rebuild
« Reply #23 on: August 22, 2010, 08:13:42 PM »
Yea I guess for different years they did different things to the boat, but kept things that where molded in. In place and just covered them over. I'm going to replace my deck this winter. But I'm going to take out the glass deck as one piece. Like a friend did. Then use a different matl. other then wood and cover it back over with the old glass. After a little work on the under side. Then you only have to deal with the thin seam. My friend was able to do it and keep his deck original. He then just sprayed a thin coat of gel on the floor. Also thanks guys for the info. I will now set my cutter just to get through the glass and into the wood.
August 24, 2010, 09:34:15 AM
Keith Knecht
Re: 222 CCP Rebuild
« Reply #24 on: August 24, 2010, 09:34:15 AM »
Here's a few more pics.
Definitely not doing things in the right order but I have to take the help I can get when I can get it.
August 24, 2010, 09:02:13 PM
222 ccp dgraf
Re: 222 CCP Rebuild
« Reply #25 on: August 24, 2010, 09:02:13 PM »
nice color!!! I cut my deck out 7 inches in all the way through all the way around then removed it. Then cut through the top layer and the plywood 3 inches all the way around  leaving the lower layer of glass as a place for the new deck to sit. The deck is made up of many small peices of 6"x6" 1/2 plywood. Both top and bottom layers of glass are 1/8 plus thick of glass. The real weight is in the fuel tank and front storage tubs they are made from very thick glass and I'd bet the two together are over 300 pounds. I am not putting the tubs back in and am glassing a lower deck between the bottom of the stringers front and rear. This gives a ton more storage and gives you storage behind the fuel tank. I took 40 plus garbage bags of wet foam out of my 222!! Any info I can give you to help just let me know.
August 24, 2010, 09:03:25 PM
222 ccp dgraf
Re: 222 CCP Rebuild
« Reply #26 on: August 24, 2010, 09:03:25 PM »
What color rub rail you gonna put back on......white?
August 25, 2010, 11:48:15 AM
Keith Knecht
Re: 222 CCP Rebuild
« Reply #27 on: August 25, 2010, 11:48:15 AM »
The rubrail will be black.  The bottom is going to get black bottom paint but will not come up on the green sides.  The cap is white.  Thanks.
August 31, 2010, 11:33:54 AM
Keith Knecht
Re: 222 CCP Rebuild
« Reply #28 on: August 31, 2010, 11:33:54 AM »
Here's a few more pics.  It's got the black bottom paint now.
August 31, 2010, 11:53:02 AM
Re: 222 CCP Rebuild
« Reply #29 on: August 31, 2010, 11:53:02 AM »
Got a name yet?  Green Hornet?   :scratch:
