Aquasport Discussion
Aquasport "no wood" hulls and deep vee
Topic: Aquasport "no wood" hulls and deep vee (Read 2726 times)
August 31, 2009, 04:44:43 AM
Read 2726 times
powrguy
August 31, 2009, 04:44:43 AM »
I have two questions for the "experts" here:
1) Which, if any, Aquasports had no wood in the stringers OR transom?
2) Which year did the Aquasport 22-2 hulls change from deep vee to the modified vee's?
August 31, 2009, 05:22:27 AM
Re: Aquasport "no wood" hulls and deep vee
August 31, 2009, 05:22:27 AM »
Welcome aboard powrguy :!: :!:
The stringers were always wood-free and after Genmar bought the company was when they began using a poured transom - post '92.
August 31, 2009, 05:37:31 AM
powrguy
August 31, 2009, 05:37:31 AM »
How about the hull design; when did the older 22-2 style deep vee become the shallower modified vee (Osprey-style?)? Did that also occur AFTER Genmar or prior? Seems that the older style (I had a 1978 222CCP) was very deep, and the newer Osprey-styles seemed like modified vee. I don't know what year the hulls on the 222 were changed, and that's what I was wondering.
thanks for the reply
August 31, 2009, 06:30:34 AM
August 31, 2009, 06:30:34 AM »
The modified V preceded the CCP. I think your 78 model was the first year, if I'm not right I know one of the CCP guys will jump in and set me straight.
August 31, 2009, 12:14:21 PM
August 31, 2009, 12:14:21 PM »
The Flatties and near flatties were first (maybe there was a semi-V in there about the same time), then the 12 degree, as you refer to as Osprey, then the CCP. With the CCP came an off-shore worthy boat we didn't have until then, at least not in a Center Console model - nice high gunwales all around and a 20 degree deadrise. Then the folks at Genmar took the best of both and combined them into the newer versions - deeper Vs and higher gunwales then their predecessors.
August 31, 2009, 01:34:05 PM
powrguy
August 31, 2009, 01:34:05 PM »
Okay, Rick, thanks.
I suspect that the old 222CCP I had (I'm remembering it as a 1978, but it could have been a 1976) had high front, low sided toward the stern. I remembet the tip of the bow at the stem to the keel seemed to stand about 4 feet tall or more; a super rough water boat to me.
Now, I'm looking at a mid-80's model CCP hull, and trying to compare the designs as to how it would be in the same conditions. As far as wood in the hull, I suspected the transom is wood-cored, but the stringers would all be non-wood.
thanks for the input.
September 02, 2009, 01:24:01 PM
KRoy
September 02, 2009, 01:24:01 PM »
I remember asking the "wood or no-wood" question about my own rig a couple of years ago. I was told that my deck and transom contain wood - 1996 Osprey 200. If that's correct, then the poured transoms didn't begin until post '96.
Hoping seabob will chime in.
KRoy
September 02, 2009, 07:15:02 PM
September 02, 2009, 07:15:02 PM »
I know my 230 is wood and it's a '92 so it was after that and Genmar owned the line then.
