Author Topic: partially submerged 96 evinrude 90 wont start  (Read 730 times)
August 18, 2009, 04:53:58 PM
Read 730 times
Blue Goose
« on: August 18, 2009, 04:53:58 PM »
Yesterday, I pulled a rookie move and forgot to put the plugs back in before launching the boat.  Before I knew what happened the boat took on a ton of water and the engine, which was still tilted up was partially submerged for about 15 minutes as I pulled the boat off the launch.  Now it won't start.  It turns over for about 1 or 2 seconds before it turns off.  Any suggestions.
August 18, 2009, 09:44:40 PM
Re: partially submerged 96 evinrude 90 wont start
« Reply #1 on: August 18, 2009, 09:44:40 PM »
Do you have a factory service manual?
If so, there is a detailed procedure on how to correctly handle a motor that has been submerged. Section 1-35 in my manual.
August 19, 2009, 08:58:06 AM
« Reply #2 on: August 19, 2009, 08:58:06 AM »
Yeah, you need to quickly address that motor situation.  If you do not have a manual, I can offer some suggestions until you get one:
Shoot some light oil (WD40, 656, etc) into the intake when turning over.  Repeat a few times.  Then pull the plugs, and flood the cylinders with the same oil.  You need to displace all the water quickly, or it will rust and bind.
Then once you get the manual, follow the steps.
Any time an engine is submerged is is a battle against time.  The sooner you either fire it up, or get it protected, the better.
September 21, 2009, 11:09:00 PM
bdtsr
« Reply #3 on: September 21, 2009, 11:09:00 PM »
Salt water or freshwater?
1978 Aquasport 200 CCP 1990 225hp Yamaha
1990 Bayliner 2302 Trophy 2000 225hp Optimax
1999 Bayliner 1950 Capri Bowrider Merc 3.0 liter I/O
1986 Arrowglass CC w/1986 Evinrude 115hp
3 Kawasaki Tandem Sport Jet skis
1993 Seadoo XP
1988 Yamaha WR500
