Author Topic: Best way to learn electrical systems?  (Read 1270 times)
August 18, 2009, 02:34:06 AM
Read 1270 times
Mark Redmon
« on: August 18, 2009, 02:34:06 AM »
Hello,
I have an Explorer 275, twin Yamaha 225s, three batteries, two 4-position battery switches, two shore power outlets, air conditioning, refridgerator, (generator is currently removed).  This electrical system is much more complex than any boat I've previously owned.  What is the best way to learn the electrical system?  My pressing question is how to use the dual battery switches.
Thanks,
Mark
Melbourne FL
Mark Redmon
Melbourne FL
2005 Explorer 275
2008 Verado 250s
August 18, 2009, 09:55:48 PM
Re: Best way to learn electrical systems?
« Reply #1 on: August 18, 2009, 09:55:48 PM »
Dual Battery switches/ three batteries (one engine each and a house)
http://gator49.hostgator.com/~zeromyst/ecatalog/images/Fig%208501-8504%20Inst%20(8500INS1).pdf
Diagram 3 should reflect what you have.
August 19, 2009, 02:16:59 AM
Mark Redmon
« Reply #2 on: August 19, 2009, 02:16:59 AM »
Thanks for the link Bob.  My education continues.
Mark Redmon
Melbourne FL
2005 Explorer 275
2008 Verado 250s
August 19, 2009, 08:49:52 AM
« Reply #3 on: August 19, 2009, 08:49:52 AM »
Mark - I recommend a setup like this to everyone:
http://www.bepmarine.com/Clusters-180.html
Look at the two outboard / three bank setup.  The advantage to these clusters is that you do not have to decide which motor charges your house batteries, or forget to have one of the motors switched to both.  In addition, let's say your motor battery shorts - this system then disconnects it from the house battery to avoid draining that bank too.  This is as "brainless" as boat electric gets once installed.
August 19, 2009, 12:09:50 PM
Mark Redmon
« Reply #4 on: August 19, 2009, 12:09:50 PM »
Thanks to all for the help.  Unfortunately I'm overseas behind a firewall right now.  When I get home I'll continue my research and study the links you have provided.
I don't understand the concept of a 'house' battery yet, but I'm sure the link will explain it to me.
Best,
Mark
Mark Redmon
Melbourne FL
2005 Explorer 275
2008 Verado 250s
August 19, 2009, 04:52:23 PM
MichaelO
« Reply #5 on: August 19, 2009, 04:52:23 PM »
Quote from: "Mark Redmon"
Are you serving the country?  If so, thank you.
Mark,
"House" battery(ies) are, in most cases, any batteries that are not your starting battery(ies).  What it really refers to is "house power," as opposed to "shore power."  Since you are seeking an understanding of the "concept" of a house battery, I'm going to give you an explanation that might be broader than your needs...
Let's forget about boats for a moment...no, really.  Let's say you have a generator at your house.  The power goes out, and you fire it up.  You flip a big switch that disconnects the power to your home from the utility (power company) and connects your generator to your home.  You are now running on "house power" as opposed to the power you would normally get from the utility.  It is house power because it is coming from your house, and not some outside source.
Back on the boat, but, let's go back in time a few decades, before the smart relays and smart inverters hit the scene.  Say, it's 1965 and you are aboard your 40' downeast lobster boat.  You have a white beard and say "arrr" a lot.  People always think you are winking at them, because you squint in the sun and think sunglasses are fruity.
All throughout the cabin, you've got power outlets.  Not one at each location, you've got three!  One is labeled   "shore power" the next says "house power" and the third says "DC."  Before any of your land lubber guests or green crew plug in their new fangled Mr Coffee or hairdryers, they have to talk to you.  Says you, "arrr, don't use that one labeled DC.  It's not for you.  You can only plug into shore power.  And if'n we ain't n'shore, you ain't got n'power."
Why three outlets?  Shore power outlets are wired to your shore power connector, which you power via the pylon at the dock.  Once you are connected, you've got plenty of power, as much as the dock and your boat are wired to handle.  Time to turn on the fridge and battery chargers.
House power outlets are the power you get from your fancy "rotating inverter" which runs off a belt from your engine.  If the engine isn't running, no power.  And even when it is, it doesn't have much capacity for power, so you have to budget it.  You know the power consumption of everything on board, and you have to choose what is on and what is off.
DC is wired to your house batteries.  As long as they are charged, DC power is available, for items that run on DC.
Now we move forward 20 years or so, and you've got a nice solid state inverter on board.  This boat only has two outlets in each location: house power, and shore power.  The DC outlets are gone.  They weren't that useful, as most people don't own many appliances that run on DC, and thanks to your inverter, you've got house power whether the engine is running or not.  That inverter is wired to your house batteries.  Why the "house batteries" and not just "batteries?"
Maybe it's the rum, or the good fishing, or perhaps just the riveting conversation but, more than once, out on anchor, with the radio playing and the cocktail lights on, the blender whirring and the VHF chattering away, you ran the batteries down, and you couldn't start the engine.  You get towed back to the marina and tell your electrician, "look, I can't have that happen again."
Five and a half weeks later, you discover the electrician has put a big red switch on your boat that says "ALL, 1, 2, NONE."  Hanging from the switch are two notes, the first is the bill, which causes blindness.  Later, your vision comes back and notice the second says, "always switch when motor is off, never when motor is on, switch to 1 when the engine is going to be off, switch to ALL when the engine is going to be on, switch to 2 if you just want to charge the starting battery, bilge on own circuit."  Makes no sense, especially the bilge part but, you play by the rules and never have a problem again (because you obey the note, and, actually replace your batteries when they are shot, unlike all of your electrician's other customers).  Okay, you have one problem, over the first winter, all your batteries fail.  You call your electrician and he says, "pull the drain plug and it won't happen again."  Sounds dumb but, come the second winter, when you lay her up on the hard, you pull that garboard drain, and come spring, the batteries are fine.
Why the rules?  Let's look at them:
A. "Always switch when the motor is off, never when the motor is on."  When you move the switch, as it goes from one position to the next, in the time between two switch positions, nothing is connected.  The alternator needs a battery connected to ballast the system.  If none is connected, the voltage can go too high, and burn up the rectifier.  This is called "load dump" and generally only occurs when the alternator is supplying a large load right before the battery is disconnected.  A large load could be something like topping up a battery that just started the engine so, one would be wise to mind this rule.  There are special diodes that can be connected to prevent it but, the most dependable ones are sacrificial (work only once).
B. "Switch to 1 when the motor is going to be off."  This switch position has your house batteries connected to your electrical system, but not your starting battery.  This allows you to relax at anchor, lights ablaze and stereo singing, and no worries of running the batteries down and not starting, because the starting battery is not connected.
C. "Switch to ALL when motor is going to be on."  This switch position has your house batteries and your starter battery connected to your system.  This allows your engines' alternator to charge all batteries simultaneously.
D. "Switch to 2 if you just want to charge the starting battery."  This switch position has only your starting battery connected to your system.  Your alternator can charge one battery much quicker than a whole bank.
E. "Bilge on own circuit."  With out getting into too many tricks involving diodes and better, the electrician has wired the automatic bilge pump before the main battery switch.  He wants to be sure, when you leave the boat, and decide to switch to "OFF," to prevent the possibility that you left something aboard turned on, and it may over-discharge your batteries, that your automatic bilge pump still functions.
And as for that drain plug when the boat is laid up on the hard?  If you leave it in, and the autobilge is wired the way your electrician did it (the right way), every time it rains, rather than the rain running out the drain, it gets pumped out by the bilge.  Since the motor isn't being run to charge the batteries, the batteries are run down too far, and damaged.
Now we move to today, and the technology has gotten even more convenient.  You have smart inverters and smart relays, and if you install enough of them, you don't have to think about anything.  Things just magically work all the time, especially in a salt water environment.   :shock:
The smart inverters actually check for shore power quite often, and when they find it, switch you over to shore power.  There are some spiffy models from companies like Xantrax, and others, that include battery chargers as well, it will automatically start charging your batteries when shore power is found.  Smart relays can be connected in various ways so that they disconnect a battery if they don't detect charging voltage from the alternator, or disconnect some or all batteries when the voltage goes below some point.  There are a ton of possibilities.  I spent many, many years as a controls engineer and we have a saying: if you can say it, we can do it.  The idea being, that if someone can give a concise description of the behavior they want from a system, the engineer can convert those words into a logical system constructed of various devices that connect and disconnect different bits to perfectly model that behavior.
Even if you install a lot of great gear, you should still have a general understanding and plan for how you will maintain necessary systems when that equipment fails.  That usually comes down to one or more big battery switches configured to suit the particular system on board.  I've no doubt that is what LilRichard has recommended.  I can't get the more details page to load so, I can't look at that right now but, chances are, if you have two engines and three batteries and a member of this forum has recommended that you buy the switch cluster for two engines and three batteries, they are probably pointing you in a good direction.  If it is the type that includes voltage sensing relays, then take a close look and ask a lot of questions.  Those things are great but, you should go into owning them understanding their limitations, and, how you will manage your system should one fail.
Two engines creates new possibilities of one fault taking out two alternators, eliminating part of the benefit of having two engines in the first place.  There are some different strategies that can be employed to best enjoy the benefits of redundancy.
Please keep asking questions about this.  Few understand it and all could benefit from knowing it better.  I enjoy the opportunity to explain it in written form as it gives me time to think out how to explain it, and as a result, I do a better job of handling it verbally with my customers.
Also, I make errors.  If anyone sees something I said that is wrong, or might be, please say so.
edit: I wouldn't think I'd need to add more to such a long post but, it occurs to me, that I didn't give the full definition of house power.  It has a second meaning, which is "non-dedicated power."  A circuit that is dedicated, say the starting battery on a boat, or the circuit that feeds the elevator in a building, is just that: dedicated to a single purpose.  House circuits are not dedicated.  They are shared, and when connecting large loads, one must make a careful analysis that they aren't overloading the circuit.  On a boat, if the starting battery circuit had a problem, and the captain is able to configure things to start from the house batteries, the fact that they are called "house batteries" should remind him/her to turn off all other loads before attempting to start.
Cheers,
Michael O'
Odonnell Marine LLC
Fairfield, CT
1975 170
1985 Wellcraft V20
August 19, 2009, 08:18:48 PM
« Reply #6 on: August 19, 2009, 08:18:48 PM »
Excellent write up. :thumright:
If I read Mark's first post correctly, he already has two 4 pole switches but then, may also have a good deal of money to spend.
August 19, 2009, 11:45:22 PM
Mark Redmon
« Reply #7 on: August 19, 2009, 11:45:22 PM »
Michael,
Thanks for the thorough (and colorful) post!  I understand the possible configurations, now I need to learn how my boat is wired.
Do the two battery switches directly relate to 1 battery each?  If so, how would the third battery be connected?
Before I take up too much of your time, I need to see how things are wired...like can I start both motors with a battery switch on 1 and the other battery switch off.  Or should I go to 'both' on both switches, unless a battery has failed, then I'd leave that battery off.
Thanks for your info regarding standard wiring configurations.  I'll experiment before I ask anymore questions.
Side note: I hear radars take a large amount of power.  My Lowrance open array won't spin on the trailer.  No error messages pop up...nothing happens.  Any chance there's insufficient power?
Thanks!
Mark
Melbourne FL
Mark Redmon
Melbourne FL
2005 Explorer 275
2008 Verado 250s
August 20, 2009, 02:04:26 AM
MichaelO
« Reply #8 on: August 20, 2009, 02:04:26 AM »
Mark,
I'm off to bed for the night but, will get back to you on the switches in the next few days.  How soon will you be back at the boat?  If you can pull the switches and trace the wires, back to the starters, the batteries, and your panel, I can be much more helpful.  Draw a good diagram.  You can do it with a trouble light and trial and error but, it can get confusing--take notes!
As to the radar (by the way, I'm not a radar tech), you need to start with these five steps:
1. Don't power it up and stand in front of it for more than a minute or two.  It's mounted above for your safety.  Do keep in mind, it is basically a weak microwave oven, and when you are directly in front of it, you are in the oven.
2. Did you press the "transmit" button?
3. Find every connection/connector, and clean them.  This will probably fix your problem.  Less likely than insufficient power is that it isn't getting the signal that tells it to spin.
4. Repeat step three.  Maybe you got a bit lazy near the end and those last few pins are green, and those last few sockets are loose.  Clean one pin.  Stop.  Put down your tools.  Wipe your hands.  Look around and stretch your neck.  Start the next pin...
5. Find the manual for your display unit and array.  If you can't find them online, call the manufacturer and customer support will email or snail mail one to you.  Once you have it, follow the troubleshooting instructions.  They are in there.  And follow them in order, as they are given in order for a good reason.
Your array should go 10 to 15 years between repairs.  But, your problem is likely a corroded connection that isn't passing a small control signal, or something amiss with your head unit.
Cheers,
Michael O'
Odonnell Marine LLC
Fairfield, CT
1975 170
1985 Wellcraft V20
August 20, 2009, 07:01:48 AM
Mark Redmon
« Reply #9 on: August 20, 2009, 07:01:48 AM »
Thanks again Michael.  I'll be back home on September 11th.  Understanding the electrical system is my first priority.  Getting the radar going is #2, and getting the generator operational is #3.  We have big aspirations...100nm offshore for tuna, swordfishing overnight in the Gulf Stream, etc.  I can't do any of that until I completely understand the electronics on the boat.  Thanks for all your help so far.
Best,
Mark
Mark Redmon
Melbourne FL
2005 Explorer 275
2008 Verado 250s
