Author Topic: 72 FB build  (Read 39053 times)
July 05, 2011, 08:45:36 PM
Reply #135
dirtwheelsfl
Re: 72 FB build
« Reply #135 on: July 05, 2011, 08:45:36 PM »
keel laid up. 12" 1708 and 10" 1700. extended about 16" with corecell.
brought it up past the bow eye.
just about leveled out...
July 06, 2011, 10:19:01 PM
Reply #136
Re: 72 FB build
« Reply #136 on: July 06, 2011, 10:19:01 PM »
Looking good!
How thick is your fairing compound on the bottom?
July 07, 2011, 06:47:41 PM
Reply #137
dirtwheelsfl
Re: 72 FB build
« Reply #137 on: July 07, 2011, 06:47:41 PM »
thicker than id like it ya know, but that area is so stout from the tabbing and extra glass on the inside that it shouldnt be an issue, especially with how strong this epoxy is. theres 3 skims over it right now, and its actually a little proud of where it needs to be. i used a long piece of aluminum angle to spread it from the keel out and it started to drag on me being so hot out, so ive got some small lines and holes to fill still. then all the fresh glass on the keel. hopefully have that about done this weekend... figure out when youre headed this way?
July 09, 2011, 12:49:43 AM
Reply #138
Re: 72 FB build
« Reply #138 on: July 09, 2011, 12:49:43 AM »
I'll be over that way the weekend of the 23rd.
One thought, to avoid any flexing issues (cracking) you might put a layer of thin mat / cloth over that epoxy filler.  I dunno if that is an "accepted practice", but seems like it couldn't hurt...
July 13, 2011, 06:48:05 PM
Reply #139
dirtwheelsfl
Re: 72 FB build
« Reply #139 on: July 13, 2011, 06:48:05 PM »
ehhh, i thought about it but i just dont think it would be of any benefit, other than to make more fairing work to fill in the weave. if anything comes apart its going to be the original first layers of mat in the bottom of the hull. this epoxy bond is not only strong, but flexible to a point... ya ill be around the 23rd pm me your plans and whatnot and well figure something out...
July 31, 2011, 07:06:04 PM
Reply #140
dirtwheelsfl
Re: 72 FB build
« Reply #140 on: July 31, 2011, 07:06:04 PM »
closer to primer...
August 13, 2011, 07:29:23 PM
Reply #141
dirtwheelsfl
Re: 72 FB build
« Reply #141 on: August 13, 2011, 07:29:23 PM »
last passes before sanding and primer...
chine repair
hi tech custom keel fairing block. guide strip tacked down with hot glue
August 13, 2011, 08:53:13 PM
Reply #142
Re: 72 FB build
« Reply #142 on: August 13, 2011, 08:53:13 PM »
NICE work. The keel work especially...like that you brought her forward to the bow-eye area.
Should make a difference in how she tracks, especially in heavy slop.
You're almost there...this last little bit will be tough, 'cause you're chomping at the bit but...as we all know, paint is 95% prep.
My guy is using a black coating in between hull sandings (raising the grit) to easily show the high/low spots. Don't know what its called...but effective. Almost like how they use candle smoke to fit fine shotguns.
You guys ever seen it used?
August 13, 2011, 09:57:16 PM
Reply #143
Re: 72 FB build
« Reply #143 on: August 13, 2011, 09:57:16 PM »
Scott, its called a "guide coat".  We use it all the time painting cars. A lot of guys use the cheapest Walmart brand black spray can they can buy. 3M has a canister of something like lampblack powder with a special applicator that looks like a wax sponge applicator. They say it works better because you are not spraying some unknown solvent on the job that might cause contamination.
http://3mcollision.com/products/fillers ... 05860.html
August 13, 2011, 10:00:10 PM
Reply #144
Re: 72 FB build
« Reply #144 on: August 13, 2011, 10:00:10 PM »
I've seen black spray paint used as a "guide coat"you spray it on and use it to see low spots as you sand with a long block sander
August 13, 2011, 10:26:38 PM
Reply #145
Re: 72 FB build
« Reply #145 on: August 13, 2011, 10:26:38 PM »
Thanks guys. My rebuilder has been and is a perfectionist. One reason why its taking so long. Really don't care. Can ride/fish/eat chicken anytime, other options. Looking now like end of October to complete the structural rebuild. First of November to begin rigging.
Dirtwheels, thanks for this side-step. The guidance the boys have given is worthwhile to all.  Thanks guys.
August 14, 2011, 01:52:55 PM
Reply #146
dirtwheelsfl
Re: 72 FB build
« Reply #146 on: August 14, 2011, 01:52:55 PM »
agreed paint is 95% prep but 100% more enjoyable than grinding glass!
ya a faint mist of black spray paint will go on the hullsides. i like to use the ridges of fairing compound left by the knife on the bottom to guide there.
November 18, 2011, 04:32:02 PM
Reply #147
dirtwheelsfl
Re: 72 FB build
« Reply #147 on: November 18, 2011, 04:32:02 PM »
been real busy but finally got some primer on. had some interprotect 2000 laying around from a bottom job on my uncles boat so i put it to use. i like to use it as a good thick first coat over raw fairing below the waterline. picking up some 545 next week for the best price.... goal is to be right side up by christmas.
this was the bad chine with the big crack in it.
stay tuned...
November 18, 2011, 06:12:22 PM
Reply #148
Capt Matt
Re: 72 FB build
« Reply #148 on: November 18, 2011, 06:12:22 PM »
Glad to see your back at it
Once she is flipped back over its smooth sailing
Capt Matt
Light tackle sportfishing
November 20, 2011, 01:11:17 PM
Reply #149
dirtwheelsfl
Re: 72 FB build
« Reply #149 on: November 20, 2011, 01:11:17 PM »
ya shouldnt be that long on the topside. all thats getting faired is the cap work and bulkhead in the front. maybe the console too... gonna go topless for awhile until i get a hardtop built.
