Author Topic: 72 FB build  (Read 39012 times)
April 18, 2011, 06:57:08 PM
Reply #105
dirtwheelsfl
Re: 72 FB build
« Reply #105 on: April 18, 2011, 06:57:08 PM »
hell no... whole boats getting awlgrip. matterhorn white with light gray nonskid
April 18, 2011, 10:49:18 PM
Reply #106
Re: 72 FB build
« Reply #106 on: April 18, 2011, 10:49:18 PM »
Good deal....is the plan to strip the anti-fouling etc. with soda-blast?
April 19, 2011, 10:55:21 AM
Reply #107
dirtwheelsfl
Re: 72 FB build
« Reply #107 on: April 19, 2011, 10:55:21 AM »
no, its really old and flaky and thin so im just gonna take the 8" to it. theres a couple layers of topside paint over the original gel im taking off though so thats where my times gonna be i think...
April 20, 2011, 09:57:29 PM
Reply #108
Re: 72 FB build
« Reply #108 on: April 20, 2011, 09:57:29 PM »
Dude, look up wet sandblasting.  You don't wanna breath that :*:, it's bad stuff!
April 20, 2011, 10:10:46 PM
Reply #109
Re: 72 FB build
« Reply #109 on: April 20, 2011, 10:10:46 PM »
Quote from: "LilRichard"
My vote goes with the graybeard....No telling what funk you could experience four layers down.
Go with the soda-blast.....its cheap. And they come to you.
Thanks LilRichard. You've been here a helluva long time...glad you're back. Make it permanent.
April 20, 2011, 10:13:38 PM
Reply #110
Re: 72 FB build
« Reply #110 on: April 20, 2011, 10:13:38 PM »
I'm always close, I am just a lurker now!  I'll post up stuff whenever I think I can add value.  Otherwise I just watch the cool rebuilds...
Wish the spring gathering was not the date it is, I am already paid to be at Jennings GP all weekend.
May 30, 2011, 08:51:22 PM
Reply #111
dirtwheelsfl
Re: 72 FB build
« Reply #111 on: May 30, 2011, 08:51:22 PM »
transom wrapped
before filling: bottom is not that bad really.... the last 5 feet or so had an s shape to it fore and aft, got the high spots grinded down now just need to fill
nice split. already have3 layers of 1708 on the inside of this
lots of shotty patchwork to be ground out
stem already has been worked on, and is surprisingly solid.
keel is a mess, had about a 3/4" curve to it the last couple feet, real wavy up past the windows too. going to take the stroke sander all the way down it . and replace that section with come corecell
June 01, 2011, 03:55:01 PM
Reply #112
Re: 72 FB build
« Reply #112 on: June 01, 2011, 03:55:01 PM »
Looks like a lot of the same stuff I encountered.  You're getting closer!
June 02, 2011, 08:05:40 PM
Reply #113
dirtwheelsfl
Re: 72 FB build
« Reply #113 on: June 02, 2011, 08:05:40 PM »
ya it looks like shes had a few meetings with the bottom in the last 40yrs!
June 02, 2011, 09:04:36 PM
Reply #114
Capt Matt
Re: 72 FB build
« Reply #114 on: June 02, 2011, 09:04:36 PM »
Very cool you have her upside down, Now what seems like the never ending sanding starts, I thought mine would be turned turtle for only a week or two max, but its been two months now.  Seems like a vicious circle of putting expensive material on then sanding it right back off. I quit taking pictures until the paint is done, Its just going so slow going its driving me crazy, seems I sand for hours and see very little progress. If there is one thing this rebuild is teaching me its patience.
Don't let it bring you down.
What are you using to do the faring with? The awlgrip 2 part faring compound is awesome.
extending that keel?
She is looking good and your catching up again
Matt
Light tackle sportfishing
June 02, 2011, 10:48:23 PM
Reply #115
dirtwheelsfl
Re: 72 FB build
« Reply #115 on: June 02, 2011, 10:48:23 PM »
ya nobody ever sees progress until paint is on it! 22ft is nothing compared to what im used to though, and im not looking for yacht quality either, as long as the bottom is nice and straight im fine. very little fairing on the top either, just probably the rear part of the cap and the deck up front, and the transom/hullside joint of course. for compound i mix the 2:1 epoxy with about 2:3 cabosil and micro balloons, depending on how thick i want it, or what kind of sandability i want. i thought about extending the keel but im just going to keep it how it was, i might gradually bring it down to nothing though instead of having it run full height all the way to the end, well see...
June 03, 2011, 10:18:51 AM
Reply #116
Re: 72 FB build
« Reply #116 on: June 03, 2011, 10:18:51 AM »
DW - Might I suggest you reconsider the keel extension?  It makes a big difference on the handling of these boats - they slide bad enough WITH the extension, without...
 :shock:
June 03, 2011, 05:12:14 PM
Reply #117
Capt Matt
Re: 72 FB build
« Reply #117 on: June 03, 2011, 05:12:14 PM »
White paint hides alot too, its not like trying to prep to paint black.
Capt Matt
June 05, 2011, 08:38:28 PM
Reply #118
dirtwheelsfl
Re: 72 FB build
« Reply #118 on: June 05, 2011, 08:38:28 PM »
well rich i managed to get ahold of a perfect piece of corecell to do that with, its about 18" past the original. looks about right now that im looking at it.. probably gonna throw the vacuum to it when i laminate it.
this area had a split and delam on the chine/hullside. 2 layers of 1708.
first round of filling blisters next will be fairing compound
windows. all wet on wet...
June 06, 2011, 08:46:16 AM
Reply #119
Re: 72 FB build
« Reply #119 on: June 06, 2011, 08:46:16 AM »
Quote from: "dirtwheelsfl"
 :thumleft:
