Author Topic: 72 FB build  (Read 39014 times)
June 26, 2011, 10:54:26 AM
Reply #120
dirtwheelsfl
Re: 72 FB build
« Reply #120 on: June 26, 2011, 10:54:26 AM »
longboard, fill, repeat...
taking off all the cracked gelcoat...
June 26, 2011, 11:47:14 AM
Reply #121
Re: 72 FB build
« Reply #121 on: June 26, 2011, 11:47:14 AM »
looking good  :salut:
Are you using an air file? A straight sander used in body shops - I guess about 15 inches long.  Would save you some time until the finish coats.
June 26, 2011, 12:06:16 PM
Reply #122
Re: 72 FB build
« Reply #122 on: June 26, 2011, 12:06:16 PM »
Quote from: "RickK"
I would not do a boat without an inline sander - that thing is worth its weight in gold... as long as you know how to use it properly!
June 26, 2011, 06:20:00 PM
Reply #123
dirtwheelsfl
Re: 72 FB build
« Reply #123 on: June 26, 2011, 06:20:00 PM »
ya ive got a 5 foot or so handboard for big areas like that just to knock the high spots down and show me where to fill. pneumatic stroke sander wont come in until its pretty close to flat. a few hours with the grinder and all the gel is gone... at least waterline and below, its fine above the waterline. got some interprotect 2000 leftover from my uncles boat to coat all the bare glass with, then whole boats getting high build, 545 and topcoat
June 26, 2011, 06:38:25 PM
Reply #124
Re: 72 FB build
« Reply #124 on: June 26, 2011, 06:38:25 PM »
Quote from: "LilRichard"
And have the CFM available - gotta have a bigger compressor otherwise you're waiting a lot.
June 26, 2011, 07:08:37 PM
Reply #125
dirtwheelsfl
Re: 72 FB build
« Reply #125 on: June 26, 2011, 07:08:37 PM »
nice grinding weather this afternoon... except for a few holes in my tarp.
June 26, 2011, 10:41:03 PM
Reply #126
Re: 72 FB build
« Reply #126 on: June 26, 2011, 10:41:03 PM »
Looks great. Hate you had to go past the gel to dig out what was shown previously...but you pulled it out by the roots..like extracting a bad tooth/teeth :lol:
Good work...and for sure you didn't cut corners.
Presume you're going back with gel on the hull bottom?
My rebuilder says that way back..it was a numbers production thing....some resin didn't set off...others were too hot....my rebuild has basically shrunk a sixteeth all around over the course of 38 years...she ought to be set-up by now :wink:
June 27, 2011, 07:36:10 AM
Reply #127
Re: 72 FB build
« Reply #127 on: June 27, 2011, 07:36:10 AM »
Quote from: "dirtwheelsfl"
June 27, 2011, 09:19:24 AM
Reply #128
Re: 72 FB build
« Reply #128 on: June 27, 2011, 09:19:24 AM »
Thanks Richard,
Should have paid less attention to the pics and more to the text.
June 27, 2011, 10:13:33 AM
Reply #129
Re: 72 FB build
« Reply #129 on: June 27, 2011, 10:13:33 AM »
No worries, I'm here to help!
 :salut:
June 27, 2011, 07:08:34 PM
Reply #130
dirtwheelsfl
Re: 72 FB build
« Reply #130 on: June 27, 2011, 07:08:34 PM »
if only i could get help with the actual work! haha
June 28, 2011, 10:03:25 AM
Reply #131
Re: 72 FB build
« Reply #131 on: June 28, 2011, 10:03:25 AM »
Hey - if you were in Tampa...
BTW, may be down in Stuart in the next few weeks, might stop by if I am invited...
June 28, 2011, 07:23:24 PM
Reply #132
dirtwheelsfl
Re: 72 FB build
« Reply #132 on: June 28, 2011, 07:23:24 PM »
ya for sure, just let me know when... im only home on the weekends.
June 28, 2011, 08:47:37 PM
Reply #133
Hawg Hunter
Re: 72 FB build
« Reply #133 on: June 28, 2011, 08:47:37 PM »
Awsome bro  shes gonna a sweetie  :salut:
Capt, Richard "DUKE" Bowen
Conyers Ga
1988 290 Aquasport XF
July 01, 2011, 10:26:56 AM
Reply #134
dirtwheelsfl
Re: 72 FB build
« Reply #134 on: July 01, 2011, 10:26:56 AM »
thanks hawg..
