Controls, Steering, and Trim Tabs
Hard to shift
Topic: Hard to shift (Read 1457 times)
July 20, 2009, 09:29:21 PM
Read 1457 times
Mike Answeeney
Hard to shift
July 20, 2009, 09:29:21 PM »
Ok, here's the deal. Recently it's been getting harder and harder to shift into and out of gear, either forward or reverse. Once in gear, throttling was easy. Some suggested the cables so here's what I've done.
I disconnected both cables from the control unit.
The throttle cable moves easily and freely and I can see the throttle mechasim on the engine move accordingly.
The shift cable could not be moved by hand by cable while attached to the engine.
Is that normal?
I removed the shift cable from the engine. The cable moves easily and freely by hand. The shift lever could not be moved by hand with a pair of pliars.
Is that normal?
Does the shift lever need the leverage of the control unit to move?
Now to the control unit.
The control unit with no cables will move through the shift motions but then hard stop where throttling usually starts. This happens in both reverse and forward.
In the neutral position, if I press the shift by pass button the throttle moves in both directions all the way easily.
I'm hoping the shift lever is stiff enough that only the control unit can move it and that all I need is a new control unit.
ANy thoughts? Does this make sense?
Mike Answeeney
1973/2008 22’2
Aquaholic
July 20, 2009, 09:48:47 PM
Asport-Rog
Re: Hard to shift
July 20, 2009, 09:48:47 PM »
Mike-
I have a different control box Morse MT-3 that had similar problems. There were different pivot points for the cable attachments that were adjustable on the control box depending on the make, year and model of the outboard. Basically, the control box had not reached past a point that gearbox was in forward or reverse and it began its acceleration cycle. Not sure if it applies to your control box but it's worth a look.
I found an adjustment for the detent on the Mercury site, again, not sure if this applies but you never know...
http://www.mercurymarine.com/_media/pdf ... ctions.pdf
-Rog
1977 AS 170
Criticism is easier than craftsmanship
July 20, 2009, 10:16:53 PM
Re: Hard to shift
July 20, 2009, 10:16:53 PM »
If you're saying the shift lever on the motor is stiff, that is
not
normal... everything should be fairly smooth and relatively easy to operate by hand. Could be your shift linkage needs to be lubricated.
I live down the street man, why don't you just bring the boat by... or I can swing by?
July 20, 2009, 10:19:04 PM
Mike Answeeney
Re: Hard to shift
July 20, 2009, 10:19:04 PM »
I saw your call just a moment ago. I'm currently on a conference call for work. I'll be done in 15mins, i'll call you.
Mike Answeeney
1973/2008 22’2
Aquaholic
July 22, 2009, 03:37:46 PM
DOCREED
Re: Hard to shift
July 22, 2009, 03:37:46 PM »
I am having the same problem with one of my merc's I have been spraying WD40 on to the shift shaft where is heads down to the lower unit. (under the carbs) It seems to help.
89 250 CCP
full transom
Twin Merc 150\'s......thirsty? YES they are.
July 27, 2009, 11:00:02 PM
bdtsr
Re: Hard to shift
July 27, 2009, 11:00:02 PM »
Most engines have a pivot point in the front of the engine for the shift linkage. These get corroded and the grease dried out. Some have nylon bushing in these pivot points (just ask how I know!). Take it apart, clean and regrease and all should be well.
1978 Aquasport 200 CCP 1990 225hp Yamaha
1990 Bayliner 2302 Trophy 2000 225hp Optimax
1999 Bayliner 1950 Capri Bowrider Merc 3.0 liter I/O
1986 Arrowglass CC w/1986 Evinrude 115hp
3 Kawasaki Tandem Sport Jet skis
1993 Seadoo XP
1988 Yamaha WR500
July 31, 2009, 02:19:57 PM
DOCREED
Re: Hard to shift
July 31, 2009, 02:19:57 PM »
do you have to remove the powerhead?
89 250 CCP
full transom
September 21, 2009, 11:11:13 PM
bdtsr
Re: Hard to shift
September 21, 2009, 11:11:13 PM »
Usually not. Remove the lower cowls and you should be able tom get to everything. Sorry for the delay in answering.
1993 Seadoo XP
1988 Yamaha WR500
September 22, 2009, 11:10:23 PM
Mike Answeeney
Re: Hard to shift
September 22, 2009, 11:10:23 PM »
I ended up replacing the cables and that actually worked, even though the other cables seemed to move freely.
Also, talking with the guys at local marina, they said the bushing on the linkage that goes down to the lower unit does cause problems sometimes. He mentioned that he has
carefully
used a torch to melt the bushing out as a quick and easy solution.
Mike Answeeney
1973/2008 22’2
Aquaholic
Hard to shift
