Author Topic: single lever vs dual lever?  (Read 864 times)
July 18, 2009, 03:22:36 PM
Read 864 times
Mike Answeeney
« on: July 18, 2009, 03:22:36 PM »
I have a single lever top mount control that I just broke.  Throttle works smooth but shifting has been getting harder and harder.  Finally today I broke the handle trying to shift it into gear.  :(
I can get a new handle but if the issue turns out to be the control box, does anyone see any advantage to the dual lever control over single lever or is it just a preference thing?
Also, any advice on where to start looking to solve the VERY stiff shift control issue?
Mike Answeeney
1973/2008 22’2
Aquaholic
July 18, 2009, 11:25:14 PM
Re: single lever vs dual lever?
« Reply #1 on: July 18, 2009, 11:25:14 PM »
Dual levers are normally only used when you have two stations.  I personally do not like two levers - too much to worry about when backing on a fish, or trying to avoid hitting a dock, etc.  IMO, stick with a single.
Check your cables, willing to bet they're toast... that's the problem 99% of the time.  Order some of the teleflex high end cables (can't remember their name), it'll be good as new.
If however the cable is good, could be you have a problem with the shift linkage inside the motor.  Once you disconnect the cable to test, you can manually actuate the linkage by hand to see if that's it.
July 19, 2009, 07:04:45 AM
« Reply #2 on: July 19, 2009, 07:04:45 AM »
check marine surplus in Bradenton for some controls... last time i checked they had a few like new sets for less than 150 bucks... we had the same problem on our searay last year. had to replace both the cables and controls.
the only single screw boats at my work that have dual lever controls are either straight inboard or have a tower...
July 19, 2009, 12:09:06 PM
« Reply #3 on: July 19, 2009, 12:09:06 PM »
Agree with above - probably cable(s).  Also I think the single lever has benefits over duals as well.  I've had both and like the single control better - it's even a little embarassing when you get ready to take off with dual controls and don't notice the engine's in neutral....  So the throttle goes down and the engine goes WAAAAAA!!! and the boat goes nowhere and your face goes  :oops:
You can probably pick up the parts you need to fix your control box on eBay:
http://motors.shop.ebay.com/items/Boat- ... 06.c0.m282
See ya on the water!
July 19, 2009, 11:20:48 PM
Mike Answeeney
« Reply #4 on: July 19, 2009, 11:20:48 PM »
Thanks for all the advice guys! I'll start with new cables and stick with the single control.
Mike Answeeney
1973/2008 22’2
Aquaholic
July 20, 2009, 01:20:01 PM
« Reply #5 on: July 20, 2009, 01:20:01 PM »
I bought a Morse/Teleflex  single lever control on E-bay for $135.00 plus shipping.
